    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 26.0k Views 9 Watching
      MrEdOne
      Sorry for Dig this topic from grave but i have the same problem like @dinkybluebug245
      I have meeting on 15:00 but calendar say its 03:00. Without PM
      I have in config timeFormat: 24.
      Everything work fine, only wrong time is show.
      And this is bug after update to last version.
        Mykle1 Project Sponsor Module Developer @MrEdOne
        @MrEdOne
        Two things to try.
        Is your time and time zone set correctly on your Pi itself?
        You could also try timeFormat: 24, in the module entry of the config.
          MrEdOne
          timeFormat: 24, in calendar module not work.
          How can i check is my time and timezone correctly set?
          Im from Poland so i set Europe/Warsaw time in raspi-config.
          My clock works correctly.
          When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.
            @MrEdOne said in Calendar times in 24 hour format?:
            That makes perfect sense. 24 hour format would NOT show AM/PM, only 12 hour format would do that.
            3:00 PM in 12 hour format
            1500 in 24 hour format (no PM)
              MrEdOne
              Yes, but it won’t change 03:00 to 15:00
                @MrEdOne
                Oh ok, that’s different
                It sounds like something is overriding the timeFormat: setting. Have you made any changes to the calendar.js file?
                  MrEdOne
                  Nope. A search only where is a timeformat in js but my knowledge is to small. :)
                    @MrEdOne
                    Are you typing timeformat ? That won’t work.
                    It has to be timeFormat with a capital F.
                    Wait a minute, the only options for timeFormat in the calendar module are absolute or relative
                      MrEdOne
                      But it not change anything.
                      With absolute and relative is the same.
                        @MrEdOne
                        It has to be timeFormat with a capital F. And at the top of your config also
                        /* Magic Mirror Config
                         * MIT Licensed.
                        var config = {
                                port: 8080,
                                language: 'en',
                                timeFormat: 24,
                                units: 'metric',
                        • 4 / 4
