    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 26.3k Views 9 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Babene1
      @Babene1 https://forum.magicmirror.builders/post/25983
      • Y Offline
        ytmytm
        Hi
        I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
        Find these lines and change lower case hh into H in time format string.
        case 24: {
        			moment.updateLocale(config.language, {
        				longDateFormat: {
        					LT: "H:mm" // FIX here: was "hh:mm"
        			break;
        This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
          MarkusBe
          I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
          Thank you!
            Mykle1 Project Sponsor Module Developer @MarkusBe
            @MarkusBe said in Calendar times in 24 hour format?:
            Quick fix is to edit this in the module:
            Or move to the developers branch of MM
              MarkusBe
              THANK YOU! That was the case! Haven’t seen this… Now it works!
                @MarkusBe
                Fantastic! Enjoy your mirror. :^)
                • 3 / 4
