    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.3k Views 9 Watching
    • SvenSommerS
      SvenSommer
      I think there is simply an understanding problem. You wrote:
      “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
      So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
      Is this correct?
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
        MrEdOne
        • SvenSommerS
          SvenSommer
          Is your google calendar in the correct time zone?
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
            MrEdOne
            You mean calendar on Google website?
            But everything work correctly until lastest update of mm
            • SvenSommerS
              SvenSommer
              Then I have no idea. Sorry…
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
                MrEdOne
                Thx for response.
                  Babene1 Project Sponsor
                  i have the same problem, maybe I have time on the weekend for more test.
                  For me it is really ugly
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @Babene1
                    @Babene1 https://forum.magicmirror.builders/post/25983
                    • Y
                      ytmytm
                      Hi
                      I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                      Find these lines and change lower case hh into H in time format string.
                      case 24: {
                      			moment.updateLocale(config.language, {
                      				longDateFormat: {
                      					LT: "H:mm" // FIX here: was "hh:mm"
                      			break;
                      This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                      Reply Quote 2
                        MarkusBe
                        I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                        Thank you!
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @MarkusBe
                          @MarkusBe said in Calendar times in 24 hour format?:
                          Quick fix is to edit this in the module:
                          Or move to the developers branch of MM
                          Reply Quote 2
                            MarkusBe
                            THANK YOU! That was the case! Haven’t seen this… Now it works!
                            • Mykle1M
                              @MarkusBe
                              Fantastic! Enjoy your mirror. :^)
