    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.0k Views 9 Watching
    • SvenSommerS
      SvenSommer
      @MrEdOne
      timeFormat uses the formatting of your operating system.
      When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
      Here is the code snippet from calender.js:
      		switch (config.timeFormat) {
      		case 12: {
      			moment.updateLocale(config.language, {
      				longDateFormat: {
      					LT: "h:mm A"
      			break;
      		case 24: {
      				longDateFormat: {
      					LT: "hh:mm"
      			break;
      What do you get, when typing date in your console?
      If it’s not in displayed in a format of 24h, change the setting of your OS.
      Maybe this helps?
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
        MrEdOne
        Here is output from date
        pi@MagicMirror:~ $ date
        wto, 25 lip 2017, 20:59:48 CEST
        Yes in 12, but in 24 I have 03:00 instead 15:00
        • SvenSommerS
          SvenSommer
          I think there is simply an understanding problem. You wrote:
          “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
          So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
          Is this correct?
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
            MrEdOne
            • SvenSommerS
              SvenSommer
              Is your google calendar in the correct time zone?
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
                MrEdOne
                You mean calendar on Google website?
                But everything work correctly until lastest update of mm
                • SvenSommerS
                  SvenSommer
                  Then I have no idea. Sorry…
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
                    MrEdOne
                    Thx for response.
                      Babene1 Project Sponsor
                      i have the same problem, maybe I have time on the weekend for more test.
                      For me it is really ugly
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Babene1
                        @Babene1 https://forum.magicmirror.builders/post/25983
                        • Y
                          ytmytm
                          Hi
                          I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                          Find these lines and change lower case hh into H in time format string.
                          case 24: {
                          				longDateFormat: {
                          					LT: "H:mm" // FIX here: was "hh:mm"
                          			break;
                          This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                            MarkusBe
                            I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                            Thank you!
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @MarkusBe
                              @MarkusBe said in Calendar times in 24 hour format?:
                              Quick fix is to edit this in the module:
                              Or move to the developers branch of MM
                                MarkusBe
                                THANK YOU! That was the case! Haven’t seen this… Now it works!
                                • Mykle1M
                                  @MarkusBe
                                  Fantastic! Enjoy your mirror. :^)
