    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 27.9k Views 9 Watching
      MrEdOne
      But it not change anything.
      With absolute and relative is the same.
        Mykle1 Project Sponsor Module Developer @MrEdOne
        @MrEdOne
        It has to be timeFormat with a capital F. And at the top of your config also
        /* Magic Mirror Config
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'en',
                timeFormat: 24,
                units: 'metric',
          MrEdOne
          Yes. I have everywhere timeFormat. on a top of config and in calendar module with capital F
            MrEdOne
            I give up. I don’t know where is error.
            • SvenSommerS Offline
              SvenSommer
              @MrEdOne
              timeFormat uses the formatting of your operating system.
              When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
              Here is the code snippet from calender.js:
              		switch (config.timeFormat) {
              		case 12: {
              			moment.updateLocale(config.language, {
              				longDateFormat: {
              					LT: "h:mm A"
              			break;
              		case 24: {
              				longDateFormat: {
              					LT: "hh:mm"
              			break;
              What do you get, when typing date in your console?
              If it’s not in displayed in a format of 24h, change the setting of your OS.
              Maybe this helps?
              Looking for some building inspiration?
              Check out my large, thin and metal framed mirror on robstechlog.com.
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
                MrEdOne
                Here is output from date
                pi@MagicMirror:~ $ date
                wto, 25 lip 2017, 20:59:48 CEST
                Yes in 12, but in 24 I have 03:00 instead 15:00
                  SvenSommer
                  I think there is simply an understanding problem. You wrote:
                  “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
                  So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
                  Is this correct?
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
                    MrEdOne
                      SvenSommer
                      Is your google calendar in the correct time zone?
                      Modules released:
                      MMM-GoogleAnalytics
                      MMM-GrafanaChart
                      MMM-GrafanaGauges
                        MrEdOne
                        You mean calendar on Google website?
                        But everything work correctly until lastest update of mm
                          SvenSommer
                          Then I have no idea. Sorry…
                          Modules released:
                          MMM-GoogleAnalytics
                          MMM-GrafanaChart
                          MMM-GrafanaGauges
                            MrEdOne
                            Thx for response.
                              Babene1 Project Sponsor
                              i have the same problem, maybe I have time on the weekend for more test.
                              For me it is really ugly
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @Babene1
                                @Babene1 https://forum.magicmirror.builders/post/25983
                                • Y Offline
                                  ytmytm
                                  Hi
                                  I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                                  Find these lines and change lower case hh into H in time format string.
                                  case 24: {
                                  				longDateFormat: {
                                  					LT: "H:mm" // FIX here: was "hh:mm"
                                  			break;
                                  This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                                    MarkusBe
                                    I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                                    Thank you!
                                      Mykle1 Project Sponsor Module Developer @MarkusBe
                                      @MarkusBe said in Calendar times in 24 hour format?:
                                      Quick fix is to edit this in the module:
                                      Or move to the developers branch of MM
                                        MarkusBe
                                        THANK YOU! That was the case! Haven’t seen this… Now it works!
                                          @MarkusBe
                                          Fantastic! Enjoy your mirror. :^)
