    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 28.6k Views 9 Watching
      MrEdOne
      I give up. I don’t know where is error.
      • SvenSommerS Offline
        SvenSommer
        @MrEdOne
        timeFormat uses the formatting of your operating system.
        When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
        Here is the code snippet from calender.js:
        		switch (config.timeFormat) {
        		case 12: {
        			moment.updateLocale(config.language, {
        				longDateFormat: {
        					LT: "h:mm A"
        			break;
        		case 24: {
        				longDateFormat: {
        					LT: "hh:mm"
        			break;
        What do you get, when typing date in your console?
        If it’s not in displayed in a format of 24h, change the setting of your OS.
        Maybe this helps?
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
          MrEdOne
          Here is output from date
          pi@MagicMirror:~ $ date
          wto, 25 lip 2017, 20:59:48 CEST
          Yes in 12, but in 24 I have 03:00 instead 15:00
            SvenSommer
            I think there is simply an understanding problem. You wrote:
            “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
            So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
            Is this correct?
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
              MrEdOne
                SvenSommer
                Is your google calendar in the correct time zone?
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                  MrEdOne
                  You mean calendar on Google website?
                  But everything work correctly until lastest update of mm
                    SvenSommer
                    Then I have no idea. Sorry…
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
                      MrEdOne
                      Thx for response.
                        Babene1 Project Sponsor
                        i have the same problem, maybe I have time on the weekend for more test.
                        For me it is really ugly
                        • strawberry 3.141S Offline
                          strawberry 3.141 Project Sponsor Module Developer @Babene1
                          @Babene1 https://forum.magicmirror.builders/post/25983
                          • Y Offline
                            ytmytm
                            Hi
                            I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                            Find these lines and change lower case hh into H in time format string.
                            case 24: {
                            				longDateFormat: {
                            					LT: "H:mm" // FIX here: was "hh:mm"
                            			break;
                            This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                              MarkusBe
                              I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                              Thank you!
                                Mykle1 Project Sponsor Module Developer @MarkusBe
                                @MarkusBe said in Calendar times in 24 hour format?:
                                Quick fix is to edit this in the module:
                                Or move to the developers branch of MM
                                  MarkusBe
                                  THANK YOU! That was the case! Haven’t seen this… Now it works!
                                    @MarkusBe
                                    Fantastic! Enjoy your mirror. :^)
