    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.3k Views 9 Watching
    • SvenSommerS
      SvenSommer
      Is your google calendar in the correct time zone?
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
        MrEdOne
        You mean calendar on Google website?
        But everything work correctly until lastest update of mm
        • SvenSommerS
          SvenSommer
          Then I have no idea. Sorry…
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
            MrEdOne
            Thx for response.
              Babene1 Project Sponsor
              i have the same problem, maybe I have time on the weekend for more test.
              For me it is really ugly
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Babene1
                @Babene1 https://forum.magicmirror.builders/post/25983
                • Y
                  ytmytm
                  Hi
                  I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                  Find these lines and change lower case hh into H in time format string.
                  case 24: {
                  			moment.updateLocale(config.language, {
                  				longDateFormat: {
                  					LT: "H:mm" // FIX here: was "hh:mm"
                  			break;
                  This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                  Reply Quote 2
                    MarkusBe
                    I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                    Thank you!
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @MarkusBe
                      @MarkusBe said in Calendar times in 24 hour format?:
                      Quick fix is to edit this in the module:
                      Or move to the developers branch of MM
                      Reply Quote 2
                        MarkusBe
                        THANK YOU! That was the case! Haven’t seen this… Now it works!
                        • Mykle1M
                          @MarkusBe
                          Fantastic! Enjoy your mirror. :^)
