    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.0k Views 9 Watching
      MrEdOne
      • SvenSommerS
        SvenSommer
        Is your google calendar in the correct time zone?
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
          MrEdOne
          You mean calendar on Google website?
          But everything work correctly until lastest update of mm
          • SvenSommerS
            SvenSommer
            Then I have no idea. Sorry…
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
              MrEdOne
              Thx for response.
                Babene1 Project Sponsor
                i have the same problem, maybe I have time on the weekend for more test.
                For me it is really ugly
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Babene1
                  @Babene1 https://forum.magicmirror.builders/post/25983
                  • Y
                    ytmytm
                    Hi
                    I also had this problem. The problem is that the time format string in modules/default/calendar/calendar.js is wrong for 24h setup.
                    Find these lines and change lower case hh into H in time format string.
                    case 24: {
                    			moment.updateLocale(config.language, {
                    				longDateFormat: {
                    					LT: "H:mm" // FIX here: was "hh:mm"
                    			break;
                    This was already fixed in development branch: https://github.com/MichMich/MagicMirror/pull/943/files
                      MarkusBe
                      I am still having this problem. I checked everything, the config file is correct, my localization of the Pi itself is ok and the changes in the calendar.js have already been made. I am still getting the calendar dates in 12h format without “A” and “P”, and I want them in “15:00” time format. Any Ideas left, how to fix this?
                      Thank you!
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @MarkusBe
                        @MarkusBe said in Calendar times in 24 hour format?:
                        Quick fix is to edit this in the module:
                        Or move to the developers branch of MM
                          MarkusBe
                          THANK YOU! That was the case! Haven’t seen this… Now it works!
                          • Mykle1M
                            @MarkusBe
                            Fantastic! Enjoy your mirror. :^)
