    Still going but I've hit a brickwall - Unable to install dependencies
    magicmirror
    12 Posts 2 Posters 6.4k Views 2 Watching
    • I Offline
      IDCreate
      Re: Beginner MagicMirror Install Issue - apt --fix-broken install
      So I’m getting ever so closer hoping that someone out there will be able to help. I’m running the latest version of
      Raspbian Stretch with desktop
      Image with desktop based on Debian Stretch
      Version: September 2017
      Release date: 2017-09-07
      Kernel version: 4.9
      I’ve done I don’t know how many Micro SD’s I’ve formatted and how many re-installs I’ve done, but I’ve finally managed to get MagicMirror2 installed or so I thought.
      I get everything almost installed and then just at the end I get this…
      Node.js installation Done!
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Counting objects: 8798, done.
      remote: Compressing objects: 100% (68/68), done.
      remote: Total 8798 (delta 46), reused 77 (delta 33), pack-reused 8695
      Receiving objects: 100% (8798/8798), 11.32 MiB | 2.78 MiB/s, done.
      Resolving deltas: 100% (4968/4968), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
      > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
      > node-gyp rebuild > build_log.txt 2>&1 || exit 0
      It’s really frustrating I’ve been on this all day and thought I had finally cracked it with the good advice from lavolp3. But unfortunately I seem to have hit a brick wall any help would be gratefully appreciated. I’m new to all this so the more simple you can make it the better thanks.
        Mykle1 Project Sponsor Module Developer @IDCreate
        @IDCreate said in Still going but I’ve hit a brickwall - Unable to install dependencies:
        First things first. Have you tried to run the mirror? The two warnings can be ignored and have no affect on the operation of the mirror. cd into the MagicMirror directory and run npm start and lets see what you get.
        You could also try this to install your missing dependencies:
        In your terminal, cd into the MagicMirror directory and run npm install
        • I Offline
          IDCreate
          Thank you Mykle,
          I’m a complete beginner and no nothing about C code or how to code a Raspberry Pi. I’m just learning as I go along so any help would be most useful.
          I’ve not run the mirror and would’nt even know where to start to do this. I’m just following the instructions from the website. I came up with this issue and I’m totally stuck.
          I’m just so grateful for people like you and this forum for yours, and everyone’s great knowledge. I’m very keen to learn, I’m dyslexic and it can some times take me longer than others to do things like this but I’m determined not to give up.
          So if you would be so kind to assist me and advise me of to what you mean by
          npm start
          Many thanks in advance for all your help.
            @IDCreate
            Ok, mate, here we go.
            • Open a terminal
            • Type cd MagicMirror and press enter
              Now your terminal will show that you are in the MagicMirror directory.
            • Type npm start and press enter
              Now your mirror software will attempt to run
            Tell me what happens when you do that
            I 2 Replies Last reply Reply Quote 0
            • I Offline
              IDCreate @Mykle1
              @Mykle1 thanks very much I don’t want to be a pain with all these questions.
              So I tried what you’ve said and I get the code below:
              > magicmirror@2.1.3 start /home/pi/MagicMirror
              > sh run-start.sh
              /home/pi/MagicMirror/node_modules/electron/index.js:9
                throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                  at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                  at Module._compile (module.js:570:32)
                  at Object.Module._extensions..js (module.js:579:10)
                  at Module.load (module.js:487:32)
                  at tryModuleLoad (module.js:446:12)
                  at Function.Module._load (module.js:438:3)
                  at Module.require (module.js:497:17)
                  at require (internal/module.js:20:19)
                  at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! Linux 4.9.59-v7+
              npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
              npm ERR! node v6.11.5
              npm ERR! npm  v3.10.10
              npm ERR! code ELIFECYCLE
              npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
              npm ERR! If you do, this is most likely a problem with the magicmirror package,
              npm ERR! not with npm itself.
              npm ERR!     sh run-start.sh
              npm ERR!     npm bugs magicmirror
              npm ERR! Or if that isn't available, you can get their info via:
              npm ERR!     npm owner ls magicmirror
              • I Offline
                IDCreate @Mykle1
                @Mykle1 I did manage to run the install as you mentioned as well before, it seems that I was in the cd MagicMirror section as you mentioned.
                pi@raspberrypi:~/MagicMirror $ npm install
                > magicmirror@2.1.3 install /home/pi/MagicMirror
                > cd vendor && npm install
                magicmirror-vendors@ /home/pi/MagicMirror/vendor
                ├── font-awesome@4.7.0
                ├── moment@2.19.1
                ├── moment-timezone@0.5.13
                └── weathericons@2.1.0
                > magicmirror@2.1.3 postinstall /home/pi/MagicMirror
                > sh installers/postinstall/postinstall.sh && npm run install-fonts
                MagicMirror installation successful!
                > magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                magicmirror-fonts@ /home/pi/MagicMirror/fonts
                └── roboto-fontface@0.8.0
                > sh run-start.sh
                npm ERR!
                > sh run-start.sh
                npm ERR!
                  ‘Electron failed to install correctly, please delete node_modules/electron and try installing again’
                  No worries. Ok, lets correct the error being reported here. It’s actually telling you what to do.
                  From your desktop (not in the terminal) go to your MagicMirror folder and open it. Now open the node_modules folder. Find the electron folder (it just says electron). Delete the electron folder.
                  Now
                  • Open a terminal
                  • Type npm install and press enter
                    This will install the electron folder again and hopefully complete this time. When that completes:
                    Now your mirror software will attempt to run againg
                  I 1 Reply Last reply Reply Quote 1
                  • I Offline
                    IDCreate @Mykle1
                    @Mykle1 so I think I’ve done this as you have said. I went onto my desktop where you see the Raspberry Pi screen like you would a computer. I went to the folder you mentioned and deleted it. I then went ahead and followed your instructions. I then went to type npm start my screen flashed up on my desktop MagicMirror2 then dispersed and is showing on my main screen but says Please create a config file. See README for more information.
                    Then below says If you get this message while your config file is already created, your config file probably contains an error. Use a JavaScript linter to validate your file?
                    I’m now unable to get to my pi via my desktop. For some strange reason after typing this I’ve just managed to get back onto my Pi via my desktop.
                    Mykle1M 2 Replies Last reply Reply Quote 0
                      @IDCreate
                      Yes you can. Press your `Alt" key and a menu will drop down at the top. Move your mouse all the way to the top until you can see it. Far left menu you can Exit the mirror and back to your desktop.
                      I’ll have the directions for you to create your config in a moment.
                      You’ll be up and running in minutes, OK?
                        Your mirror will be running by the time you finish following this very short tutorial that I wrote just for you. :-)
                        https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                        • I Offline
                          IDCreate @Mykle1
                          @Mykle1 ok thanks so I have the mirror screen on my desktop and the menu bar after I pressed alt. What do I do know close it down?
                            @IDCreate
                            You didn’t read what I wrote?
                            Far left menu says File, click it and click Quit, or Exit (depending on version
