    Still going but I've hit a brickwall - Unable to install dependencies
    magicmirror
    12 Posts 2 Posters 6.5k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @IDCreate
      @IDCreate said in Still going but I’ve hit a brickwall - Unable to install dependencies:
      I’m new to all this so the more simple you can make it the better thanks.
      First things first. Have you tried to run the mirror? The two warnings can be ignored and have no affect on the operation of the mirror. cd into the MagicMirror directory and run npm start and lets see what you get.
      You could also try this to install your missing dependencies:
      In your terminal, cd into the MagicMirror directory and run npm install
      • I Offline
        IDCreate
        Thank you Mykle,
        I’m a complete beginner and no nothing about C code or how to code a Raspberry Pi. I’m just learning as I go along so any help would be most useful.
        I’ve not run the mirror and would’nt even know where to start to do this. I’m just following the instructions from the website. I came up with this issue and I’m totally stuck.
        I’m just so grateful for people like you and this forum for yours, and everyone’s great knowledge. I’m very keen to learn, I’m dyslexic and it can some times take me longer than others to do things like this but I’m determined not to give up.
        So if you would be so kind to assist me and advise me of to what you mean by
        npm start
        Many thanks in advance for all your help.
          @IDCreate
          Ok, mate, here we go.
          • Open a terminal
          • Type cd MagicMirror and press enter
            Now your terminal will show that you are in the MagicMirror directory.
          • Type npm start and press enter
            Now your mirror software will attempt to run
          Tell me what happens when you do that
          I 2 Replies Last reply Reply Quote 0
          • I Offline
            IDCreate @Mykle1
            @Mykle1 thanks very much I don’t want to be a pain with all these questions.
            So I tried what you’ve said and I get the code below:
            > magicmirror@2.1.3 start /home/pi/MagicMirror
            > sh run-start.sh
            /home/pi/MagicMirror/node_modules/electron/index.js:9
              throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
            Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions..js (module.js:579:10)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Module.require (module.js:497:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
            npm ERR! Linux 4.9.59-v7+
            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
            npm ERR! node v6.11.5
            npm ERR! npm  v3.10.10
            npm ERR! code ELIFECYCLE
            npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
            npm ERR! If you do, this is most likely a problem with the magicmirror package,
            npm ERR! not with npm itself.
            npm ERR!     sh run-start.sh
            npm ERR!     npm bugs magicmirror
            npm ERR! Or if that isn't available, you can get their info via:
            npm ERR!     npm owner ls magicmirror
            npm ERR!     /home/pi/MagicMirror/npm-debug.log
            • I Offline
              IDCreate @Mykle1
              @Mykle1 I did manage to run the install as you mentioned as well before, it seems that I was in the cd MagicMirror section as you mentioned.
              pi@raspberrypi:~/MagicMirror $ npm install
              > magicmirror@2.1.3 install /home/pi/MagicMirror
              > cd vendor && npm install
              magicmirror-vendors@ /home/pi/MagicMirror/vendor
              ├── font-awesome@4.7.0
              ├── moment@2.19.1
              ├── moment-timezone@0.5.13
              └── weathericons@2.1.0
              > magicmirror@2.1.3 postinstall /home/pi/MagicMirror
              > sh installers/postinstall/postinstall.sh && npm run install-fonts
              MagicMirror installation successful!
              > magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
              > cd fonts && npm install
              magicmirror-fonts@ /home/pi/MagicMirror/fonts
              └── roboto-fontface@0.8.0
              > sh run-start.sh
              npm ERR!
              > sh run-start.sh
              npm ERR!
                ‘Electron failed to install correctly, please delete node_modules/electron and try installing again’
                No worries. Ok, lets correct the error being reported here. It’s actually telling you what to do.
                From your desktop (not in the terminal) go to your MagicMirror folder and open it. Now open the node_modules folder. Find the electron folder (it just says electron). Delete the electron folder.
                Now
                • Open a terminal
                • Type npm install and press enter
                  This will install the electron folder again and hopefully complete this time. When that completes:
                  Now your mirror software will attempt to run againg
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  IDCreate @Mykle1
                  @Mykle1 so I think I’ve done this as you have said. I went onto my desktop where you see the Raspberry Pi screen like you would a computer. I went to the folder you mentioned and deleted it. I then went ahead and followed your instructions. I then went to type npm start my screen flashed up on my desktop MagicMirror2 then dispersed and is showing on my main screen but says Please create a config file. See README for more information.
                  Then below says If you get this message while your config file is already created, your config file probably contains an error. Use a JavaScript linter to validate your file?
                  I’m now unable to get to my pi via my desktop. For some strange reason after typing this I’ve just managed to get back onto my Pi via my desktop.
                    @IDCreate
                    Yes you can. Press your `Alt" key and a menu will drop down at the top. Move your mouse all the way to the top until you can see it. Far left menu you can Exit the mirror and back to your desktop.
                    I’ll have the directions for you to create your config in a moment.
                    You’ll be up and running in minutes, OK?
                      Your mirror will be running by the time you finish following this very short tutorial that I wrote just for you. :-)
                      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                      • I Offline
                        IDCreate @Mykle1
                        @Mykle1 ok thanks so I have the mirror screen on my desktop and the menu bar after I pressed alt. What do I do know close it down?
                          @IDCreate
                          You didn’t read what I wrote?
                          Far left menu says File, click it and click Quit, or Exit (depending on version
