    Still going but I've hit a brickwall - Unable to install dependencies
    magicmirror
    12 Posts 2 Posters 5.7k Views 2 Watching
    • I Offline
      IDCreate @Mykle1
      @Mykle1 thanks very much I don’t want to be a pain with all these questions.
      So I tried what you’ve said and I get the code below:
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/index.js:9
        throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.9.59-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! node v6.11.5
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      • I Offline
        IDCreate @Mykle1
        @Mykle1 I did manage to run the install as you mentioned as well before, it seems that I was in the cd MagicMirror section as you mentioned.
        pi@raspberrypi:~/MagicMirror $ npm install
        > magicmirror@2.1.3 install /home/pi/MagicMirror
        > cd vendor && npm install
        magicmirror-vendors@ /home/pi/MagicMirror/vendor
        ├── font-awesome@4.7.0
        ├── moment@2.19.1
        ├── moment-timezone@0.5.13
        └── weathericons@2.1.0
        > magicmirror@2.1.3 postinstall /home/pi/MagicMirror
        > sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        > magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        magicmirror-fonts@ /home/pi/MagicMirror/fonts
        └── roboto-fontface@0.8.0
        > sh run-start.sh
        npm ERR!
        > sh run-start.sh
        npm ERR!
          Mykle1 Project Sponsor Module Developer @IDCreate
          @IDCreate said in Still going but I’ve hit a brickwall - Unable to install dependencies:
          ‘Electron failed to install correctly, please delete node_modules/electron and try installing again’
          No worries. Ok, lets correct the error being reported here. It’s actually telling you what to do.
          From your desktop (not in the terminal) go to your MagicMirror folder and open it. Now open the node_modules folder. Find the electron folder (it just says electron). Delete the electron folder.
          Now
          • Open a terminal
          • Type cd MagicMirror and press enter
            Now your terminal will show that you are in the MagicMirror directory.
          • Type npm install and press enter
            This will install the electron folder again and hopefully complete this time. When that completes:
          • Type npm start and press enter
            Now your mirror software will attempt to run againg
            Tell me what happens when you do that
          I 1 Reply Last reply Reply Quote 1
          • I Offline
            IDCreate @Mykle1
            @Mykle1 so I think I’ve done this as you have said. I went onto my desktop where you see the Raspberry Pi screen like you would a computer. I went to the folder you mentioned and deleted it. I then went ahead and followed your instructions. I then went to type npm start my screen flashed up on my desktop MagicMirror2 then dispersed and is showing on my main screen but says Please create a config file. See README for more information.
            Then below says If you get this message while your config file is already created, your config file probably contains an error. Use a JavaScript linter to validate your file?
            I’m now unable to get to my pi via my desktop. For some strange reason after typing this I’ve just managed to get back onto my Pi via my desktop.
            Mykle1M 2 Replies Last reply Reply Quote 0
              @IDCreate
              Yes you can. Press your `Alt" key and a menu will drop down at the top. Move your mouse all the way to the top until you can see it. Far left menu you can Exit the mirror and back to your desktop.
              I’ll have the directions for you to create your config in a moment.
              You’ll be up and running in minutes, OK?
                Your mirror will be running by the time you finish following this very short tutorial that I wrote just for you. :-)
                https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                • I Offline
                  IDCreate @Mykle1
                  @Mykle1 ok thanks so I have the mirror screen on my desktop and the menu bar after I pressed alt. What do I do know close it down?
                    @IDCreate
                    You didn’t read what I wrote?
                    Far left menu says File, click it and click Quit, or Exit (depending on version
