    Voice/motion control
    utility
    72 Posts 15 Posters 100.5k Views 14 Watching
    • mochmanM Offline
      mochman Module Developer
      @coolbotic I just made a motion control module. It’s no where near as intricate as leapmotion though. It just detects hand movements, using 2 ultrasonic sensors and give you a swipe left, right, and press notification. If you have any ideas on how to improve it, please let me know.
      • MitchfarinoM Offline
        Mitchfarino Module Developer @MichMich
        @MichMich This guy has done it, using your MM2
        https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
        • T Offline
          tyho
          @MichMich Well what about annyang. i got it working on my rpi3. See https://github.com/TalAter/annyang-electron-demo. I tried to make a module with the use of your readme file but it didn’t work. (I am not rly (rly not) good at coding).
          The demo needs some extra dependencies so it’s not simple to write a module. Can you maybe give it a try?
          What about the demo. i didn’t get the actual response in my browser but when i opened the console i saw he recognized my words really clear and fast. (and that for a dutch guy ^^)
          I think if you get this running with basic setup (hello, show map, show picture), it could even be expanded to run shells with your voice to turn on and off your monitor. (and other crazy ideas :P)
          • MichMichM Offline
            MichMich
            You can just install extra dependencies using npm install. The problem of using annoying is that it has an API limit afaik. So you can’t use it indefinitely.
            • T Offline
              tyho @MichMich
              @MichMich is it possible to restart annyang when the onend event is called?
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @tyho
                @tyho It probably is. I did not look into the Annyang API.
                • T Offline
                  tyho
                  @coolbotic @MichMich I got something working. I combined annyang and angular (from snippets and reading de api). and it works unlimited so far.
                  The thing is i got it only working separate. I have to cd to the folder and then npm install && npm start to run.
                  It’s realy basic, cuz i am not a programmer. (i only added simple commands and i get the response i want in my browser). But it’s easy now to expand. I am working on a command to turn on and off my monitor by shell commands but i didn’t got it running yet.
                  The thing is i don’t know how to include it in the mirror. And honestly i don’t know how to post it somewhere like github -_- so others can help :p
                  T MitchfarinoM 2 Replies Last reply Reply Quote 0
                  • T Offline
                    tyho @tyho
                    I also managed to turn my sceen on and off by voice.
                      Mitchfarino Module Developer @tyho
                      @tyho It would be good to see what you’ve done, if you could post a tutorial or something
                      • T Offline
                        tyho @Mitchfarino
                        how does github work?
                        MitchfarinoM 1 Reply Last reply Reply Quote 0
                          @tyho Not a clue
                          @KirAsh4 will know
                          • ? Offline
                            A Former User
                            @tyho github works as a distributed revision control and scm, so to use it you need to log an acct there, grab the desktop sync software for whatever os flavour you’re running, create a repository and then sync it to the path of your local working copy
                            • T Offline
                              tyho @Guest
                              @sullit ty. I’ll first finish the flickr and maps voice control and then i’ll check github.
                              any suggestions how to add this as module?
                              • KirAsh4K Offline
                                KirAsh4 Moderator
                                As @sullit mentioned, Github is a code repository, any code, or to be more precise, any text. It’s a way for a coder to keep revisions on their code, and able to publish it to the general public. The code lives on whatever development machine you are using, and you sync, or mirror it to Github. This allows a coder to work on their code locally, break it, fix it, change it, do whatever, and when they’re done, push it up to Github to store and eventually release to the public. This also allows a coder to roll back their code. If while working locally they broke something and can’t figure out what happened, they can pull code back out from the repository and either merge it back in, or just compare and see where things went haywire. It’s a beautiful thing.
                                And while it may have a bit of a steep learning curve, trust me when I say this, it will save your sanity.
                                There are a lot of different guides, both on Github as well as out in the wild about how to use it.
                                Overall: https://guides.github.com/
                                Short and sweet beginner’s guide: https://guides.github.com/activities/hello-world/
                                T 1 Reply Last reply Reply Quote 1
                                • T Offline
                                  tyho @KirAsh4
                                  @KirAsh4 @sullit @Mitchfarino @MichMich
                                  i managed to make a github. But i still don’t get the pull push thing but that will come later.
                                  You can see what i have made so far here: https://github.com/ME-TYHO/MM2-Voice-Control-Module
                                  I hope some guys here can help make this module.
                                    alexyak
                                    Besides the ability to recognize the speech you also need to start the recognition with annyang. There should be an always listening component that reacts on a key word and starts annyang.
                                    • T Offline
                                      tyho @alexyak
                                      @alexyak at the moment annyang is always lisening. If i come back in à couple of hours i can still make my commands.
                                        alexyak @tyho
                                        @tyho You will quickly run out of quota if it listens continuously.
                                          alexyak
                                          It looks like this guy has figured it out:
                                          http://docs.smart-mirror.io
                                          • T Offline
                                            tyho @alexyak
                                            @alexyak true, hè got à separate speech module for unlock annyang. Still you get max 50 commands a day. If i use annyang in chrome i got unlimited commands. So i guess it has something to do with api key what is burned into chrome browser. Maybe there is a way to use this api key.
                                            • 2 / 4
