    Voice/motion control
    utility
    72 Posts 15 Posters 106.1k Views 14 Watching
      Mitchfarino Module Developer @tyho
      @tyho It would be good to see what you’ve done, if you could post a tutorial or something
      T 1 Reply Last reply
      • T
        tyho @Mitchfarino
        how does github work?
        M 1 Reply Last reply
          @tyho Not a clue
          @KirAsh4 will know
            A Former User
            @tyho github works as a distributed revision control and scm, so to use it you need to log an acct there, grab the desktop sync software for whatever os flavour you’re running, create a repository and then sync it to the path of your local working copy
            • T
              tyho @Guest
              @sullit ty. I’ll first finish the flickr and maps voice control and then i’ll check github.
              any suggestions how to add this as module?
              • K
                KirAsh4 Moderator
                As @sullit mentioned, Github is a code repository, any code, or to be more precise, any text. It’s a way for a coder to keep revisions on their code, and able to publish it to the general public. The code lives on whatever development machine you are using, and you sync, or mirror it to Github. This allows a coder to work on their code locally, break it, fix it, change it, do whatever, and when they’re done, push it up to Github to store and eventually release to the public. This also allows a coder to roll back their code. If while working locally they broke something and can’t figure out what happened, they can pull code back out from the repository and either merge it back in, or just compare and see where things went haywire. It’s a beautiful thing.
                And while it may have a bit of a steep learning curve, trust me when I say this, it will save your sanity.
                There are a lot of different guides, both on Github as well as out in the wild about how to use it.
                Overall: https://guides.github.com/
                Short and sweet beginner’s guide: https://guides.github.com/activities/hello-world/
                • T
                  tyho @KirAsh4
                  @KirAsh4 @sullit @Mitchfarino @MichMich
                  i managed to make a github. But i still don’t get the pull push thing but that will come later.
                  You can see what i have made so far here: https://github.com/ME-TYHO/MM2-Voice-Control-Module
                  I hope some guys here can help make this module.
                  • A
                    alexyak
                    Besides the ability to recognize the speech you also need to start the recognition with annyang. There should be an always listening component that reacts on a key word and starts annyang.
                    • T
                      tyho @alexyak
                      @alexyak at the moment annyang is always lisening. If i come back in à couple of hours i can still make my commands.
                      A 1 Reply Last reply
                      • A
                        alexyak @tyho
                        @tyho You will quickly run out of quota if it listens continuously.
                        • A
                          alexyak
                          It looks like this guy has figured it out:
                          http://docs.smart-mirror.io
                          • T
                            tyho @alexyak
                            @alexyak true, hè got à separate speech module for unlock annyang. Still you get max 50 commands a day. If i use annyang in chrome i got unlimited commands. So i guess it has something to do with api key what is burned into chrome browser. Maybe there is a way to use this api key.
                            • T
                              tyho
                              i can’t get it to work with the sphinx package. simply cuz i am not smart enough -_-
                              I get pocketsphinx regognize my words but not in the js envirement and i don’t get response out of it.
                              I think i just use “blather” for the time being to control my monitor on and off. I hope someone make a voice module soon. ^^
                              • T
                                tyho
                                @michmich @KirAsh4 running a simple html with the following code gets me more results then 50. and also run more then a hour already.
                                I run it with https in chrome and get:
                                0_1469556674964_upload-8cd7fc28-ea4b-4861-9aa3-a711d2c8e440
                                has this something to do with chrome that there is no limit?
                                • K
                                  KirAsh4 Moderator
                                  What’s the HTML/CSS output look like? That’s usually the first thing to look at when stuff like this happens and it’s not the expected result.
                                  • T
                                    tyho
                                    nvm i already see it depends on the chrome api key and not the chromium…
                                    What about cloud voice api?
                                    • K
                                      KirAsh4 Moderator
                                      FYI, setting 'TEXTAREA' size works fine in Chrome, both by using 'cols' and 'rows' as well as using CSS styling 'width' and 'height'.
                                      • T
                                        tyho
                                        Sorry for spamming what about: https://github.com/cmusphinx/node-pocketsphinx
                                        • T
                                          tyho @KirAsh4
                                          @KirAsh4 The output is exactly what i want. It’s just the proof i get over the api limit of 50 request/day when i use chrome. The thing is when i use this in electron/chromium i have a limit of 50…
                                          I am still searching for a way to get around the limit or perhaps use another api/voice recognizer…
                                          • A
                                            alexyak
                                            I think using https://snowboy.kitt.ai is the best approach right now for detecting a hot word and then continuing with the google one (annyang). The same way the guy at the http://docs.smart-mirror.io has done it.
                                            • 2 / 4
