    Browser access in LAN not working
    5 Posts 3 Posters 4.0k Views 3 Watching
    • A
      Albert2002
      Hi there,
      I was running MM in an older Version, somewhere from June and it was fine. I Tried to update with “git pull” but got errors, So out of performance reason I decided to do a fresh installation of MM. I renamed the old MM directory and installed the latest v2.1.3.
      I’ve installed all my old modules and used my old config as well. Everything was working fine except MMM-Remote-Control.
      I figured out that I don’t have access to MM via my Browser as well e.g http://RaspberryIP:8080. When I try so I get a “access denied” error in my Browser ( Firefox, Opera, Vivaldi) Even when am via VNC connected to the Rapberry starting a Browser there. Only localhost:8080 is working.
      I don’t get any errors in mm-error log.
      I already installed a second MM with 2.1.3 on a different Pi but still the same problem. No access to MM via my Browser. Any idea what to do?
      mm- out:
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.1.3
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-DWD-WarnWeather
      Module helper loaded: MMM-PNews
      Module helper loaded: internet-monitor
      Module helper loaded: MMM-MovieListings
      Module helper loaded: MMM-Fuel
      Module helper loaded: MMM-NetworkScanner
      Module helper loaded: MMM-nasaastropic
      Module helper loaded: MMM-SystemStats
      No helper found for module: MMM-Carousel.
      Module helper loaded: MMM-Events
      Module helper loaded: MMM-xiaomi
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started...
      Connecting socket for: MMM-PNews
      Starting module: MMM-PNews
      Starting module: newsfeed
      Connecting socket for: internet-monitor
      internet-monitor helper started ...
      Connecting socket for: MMM-MovieListings
      MMM-MovieListing helper started...
      Connecting socket for: MMM-Fuel
      Starting module helper: MMM-Fuel
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      Connecting socket for: MMM-nasaastropic
      Starting node helper: MMM-nasaastropic
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-Events
      Starting node_helper for: MMM-Events
      Connecting socket for: MMM-xiaomi
      Starting xiaomi helper
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/htc.one.m2304%40gmail.com/private-14fa662585128c24fef964b020903be5/basic.ics - Interval: 300000
      Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
      Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
      starting internet monitor node helper
      MMM-NetworkScanner received CONFIG
      astro helper: config received
      retrieveAndUpdate()
      Triggering Xiaomi Gateway upate
      NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/Jet67P_Rosetta_960.jpg
      Found device with ID 158d000119fcb2 of type magnet
      Found device with ID 158d00013e28ee of type power-plug
      Found device with ID 158d00015aa973 of type controller
      Found device with ID 158d00015736a8 of type sensor
      My config ( I have removed all the config entrys from modules to keep it more clearly here) :
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: [],
      	language: 'de',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			module: 'currentweather',
      			module: 'weatherforecast',
      			module: 'MMM-Remote-Control',
      			// uncomment the following line to show the URL of the remote control on the mirror
      			//position: 'bottom_left'
      			// you can hide this module afterwards from the remote control itself
      			module: 'MMM-DWD-WarnWeather',
      			module: 'MMM-PNews',
      			module: 'newsfeed',
      			module: 'internet-monitor',
      			module: 'MMM-MovieListings',
      			module:	'MMM-Fuel',
      			module: 'MMM-NetworkScanner',
      			module: 'MMM-nasaastropic',
      			module: 'MMM-SystemStats',
      			module: 'MMM-Carousel',
      			module: 'MMM-Events',
      		module: 'MMM-xiaomi',
      Browserdebug on the localhost:8080
      main.js:404 Initializing MagicMirror.
      translator.js:197 Loading core translation file: translations/de.json
      translator.js:219 Loading core translation fallback file: translations/en.json
      loader.js:182 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
      module.js:406 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.1.0 - Current version: 2.1.3
      module.js:408 Version is ok!
      module.js:414 Module registered: MMM-Remote-Control
      loader.js:152 Bootstrapping module: MMM-Remote-Control
      loader.js:157 Scripts loaded for: MMM-Remote-Control
      loader.js:197 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
      loader.js:159 Styles loaded for: MMM-Remote-Control
      loader.js:161 Translations loaded for: MMM-Remote-Control
      loader.js:197 Load stylesheet: css/custom.css
      MMM-Remote-Control.js:21 Starting module: MMM-Remote-Control
      main.js:422 All modules started!
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Albert2002
        @Albert2002
        Add address: "0.0.0.0", to your config:
        var config = {
            port: 8080,
            address: "0.0.0.0",
            ipWhitelist: [], // Set [] to allow all IP addresses.
            language: "en",
            timeFormat: 12,
            units: "imperial",
        Reply Quote 3
        • A
          Albert2002
          I’ve tried
          address: "Localhost",
          already without luck, but
          address: "0.0.0.0",
          is working for me!
          You made my day! Thank you!
          Reply Quote 4
          • Mykle1M
            @Albert2002 said in Browser access in LAN not working:
            Excellent! You are welcome. :-)
            Maybe localhost (lower case)?
            • E
              E3V3A
              I can confirm that address: "localhost" does not allow access from LAN. That is specifying the interface. So it need to be an interface facing your ethernet/wlan, i.e. “0.0.0.0” (any iface).
              “Everything I do (here) is for free – altruism is the way!”
              MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
              Reply Quote 1
