    Custom module to run python script
    4 Posts 4 Posters 4.0k Views 4 Watching
      sureshkocherla
      I have one python script. I want to create a new custom module to run the python script automatically
      Kindly guide me.
        Sputnik
        I would like to do the same thing :-)
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
        • P Offline
          pinsdorf Module Developer
          A good starting point might be the module MMM-dht by @nebulx29. It executes a custom shell command to read data from a sensor. You’ll find the invocation of the script in file node_helper.js. NB: it makes three calls, because it needs three values from the sensor.
          In your use case, you’d call Python with your script name instead.
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Sputnik
            @Sputnik the facerecognition moduel of @paviro makes also heavy use of python scripts, take a look here https://github.com/paviro/MMM-Facial-Recognition/blob/master/node_helper.js
