    Weather from a different source
    8 Posts 3 Posters 3.2k Views 2 Watching
    • C Offline
      ChrisEW
      I currently use the openweathermap function to display the weather on my mirror.
      Just wondering if there are other apps that might work, providing (I guess) that an appid is available? I would like to display the info from a weatherunderground link.
      Can I do that?
        Mykle1 Project Sponsor Module Developer @ChrisEW
        @ChrisEW
        The hottest new weather module that uses weatherUnderground is
        https://github.com/cowboysdude/MMM-NOAA
        And here you can find other modules that might interest you.
        https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules
        • C Offline
          ChrisEW @Mykle1
          @Mykle1 Can’t seem to get this running. Copied the code and dropped it in. config:check is telling me there is a problem with the last line with { } issues. But the coding is straightforward as far as I can see with only one set of nested { and }symbols. What gives?
            @ChrisEW said in Weather from a different source:
            What gives?
            Well, there is a missing comma after showHum: true in the config example but that doesn’t seem to be the only issue. I contacted the author and made him aware of it. I’m sure he’ll fix it ASAP. That is, after he finishes the work that pays his bills.
            I know he made some significant upgrades just yesterday. He probably missed something when pushing it to the repo.
            • C Offline
              ChrisEW @Mykle1
              @Mykle1 I added the comma and it doesn’t crash anymore, but nothing shows up on the mirror either. Maybe because I already have another module in top_right ?
              • cowboysdudeC Offline
                cowboysdude Module Developer @ChrisEW
                Run your mirror ‘npm start dev’ and see what errors there are in the developer window.
                PS I fixed the example on github to include the comma :)
                • C Offline
                  ChrisEW @cowboysdude
                  @cowboysdude I see the split window but am not familiar that level of troubleshooting. So I can’t really tell what’s happening. All other modules work just fine, but MMM-NOAA is a no show.
                  I have an API key, have selected the specific weather station ID relevant to me, and other than adding that comma, the .js file is virgin.
                    @ChrisEW
                    Post your config entry for NOAA here (in a code block) and leave the weather station ID in so I can test that as well
