Weather from a different source
I currently use the openweathermap function to display the weather on my mirror.
Just wondering if there are other apps that might work, providing (I guess) that an appid is available? I would like to display the info from a weatherunderground link.
Can I do that?
The hottest new weather module that uses weatherUnderground is
https://github.com/cowboysdude/MMM-NOAAAnd here you can find other modules that might interest you.
https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules -
@Mykle1 Can’t seem to get this running. Copied the code and dropped it in. config:check is telling me there is a problem with the last line with { } issues. But the coding is straightforward as far as I can see with only one set of nested { and }symbols. What gives?
@ChrisEW said in Weather from a different source:
What gives?
Well, there is a missing comma after
showHum: truein the config example but that doesn’t seem to be the only issue. I contacted the author and made him aware of it. I’m sure he’ll fix it ASAP. That is, after he finishes the work that pays his bills.I know he made some significant upgrades just yesterday. He probably missed something when pushing it to the repo.
@Mykle1 I added the comma and it doesn’t crash anymore, but nothing shows up on the mirror either. Maybe because I already have another module in top_right ?
Run your mirror ‘npm start dev’ and see what errors there are in the developer window.
PS I fixed the example on github to include the comma :)
@cowboysdude I see the split window but am not familiar that level of troubleshooting. So I can’t really tell what’s happening. All other modules work just fine, but MMM-NOAA is a no show.
I have an API key, have selected the specific weather station ID relevant to me, and other than adding that comma, the .js file is virgin. -
Post your config entry for NOAA here (in a code block) and leave the weather station ID in so I can test that as well
