    Tado module?
    35 Posts 5 Posters 32.9k Views 5 Watching
    • C Offline
      charliwest
      Don’t really get how to build these modules, although will take a stab at reading through some docs, but was wondering if anyone is already working on a tado module, I found this https://github.com/dVelopment/node-tado which I think might be useful as well?
        dinkybluebug245 @charliwest
        This would be awesome!
        • C Offline
          charliwest
          OK, well I have had a play and I can get this working via the API with curl commands…I guess its s start, then I looked at the module docs and woosh, it went right over my head. If it helps anyone here is the process for doing it in bash.
          ##Fill in your email and your password
          USERNAME=you@youremail.com
          PASSWORD=yourPassword
          ####You probably don’t want to edit below here####
          ##Grabs a cookie to stash your session details
          curl --silent “https://my.tado.com/j_spring_security_check?j_password=$PASSWORD&j_username=$USERNAME” --data-binary “{}” --cookie-jar /tmp/tadocookies
          ##Grabs your unique home ID from a bunch of info
          curl --silent “https://my.tado.com/api/v1/me” -H “Referer: https://my.tado.com/” --cookie /tmp/tadocookies > homeId
          HOMEID=$(grep -o “homeId.," homeId| awk -F, ‘{print $1}’|awk -F: ‘{print $2}’)
          ##Now uses your home ID to get the current temp of your home and displays it
          curl --silent “https://my.tado.com/api/v1/home/$HOMEID/hvacState” -H “Referer: https://my.tado.com/” --cookie /tmp/tadocookies > temp
          TEMP=$(grep -o "celsius.
          ,” temp| awk -F, ‘{print $1}’|awk -F: ‘{print $2}’)
          echo “$TEMP”
          If someone can use that to make an MMM pretty please ;)
          • K Offline
            krisalexroberts
            Has anyone been able to look at this yet?
            • K Offline
              krisalexroberts
              There is a tado API, but I don’t know how to use this to display data on the MagicMirror
              https://my.tado.com/mobile/1.9/getCurrentState?username=xxxxxxxxxxxx@xxxxx.xxx&password=yyyyyyyyyyyyyyyyy
              I guess in its simplest form, we just need a module which connects to the above URL and then pulls information based on specific strings. eg: “insideTemp”:20.61
              I can do this in Python… not Javascript though
              Example of output
              {“success”:true,“operation”:“HOME”,“preheating”:false,“preheatingTargetOperation”:null,“autoOperation”:“HOME”,“operationTrigger”:“SYSTEM”,“insideTemp”:20.61,“setPointTemp”:20.8,“controlPhase”:“STEADY”,“currentUserPrivacyEnabled”:false,“currentUserGeoStale”:null,“deviceUpdating”:false,“homeId”:xxx,“heatingOn”:true,“internetGatewayType”:“GW02”,“internetGatewayConnected”:true,“heatingMuscleType”:“BU01”,“heatingMuscleConnected”:true,“insideTemperatureSensorType”:“RU01”,“insideTemperatureSensorConnected”:true,“settingsEnabled”:true,“fallbackOperation”:false,“helpUrl”:“https://support.tado.com/hc/","pendingDeviceInstallation”:false}
                dinkybluebug245
                I think the following variables would be quite useful.
                Insidetemp - displayed as a number
                setPointTemp - displayed as a number
                heatingon - displayed as an flame icon if set to true
                Maybe like this
                21.3° / 15.2° / 0_1479296200918_upload-f38c73ad-e4a6-4519-9068-47ca54312530
                Where the first temp in bold is current temp, the next is the trigger temperature (ie when the heating would come on) Would anyone else add anything different?
                Perhaps mode might be useful as well, as an icon which is held in variable autoOperation. I think the different options here are HOME, AWAY, MANUAL, and the other one for nighttime (not sure what this is called)
                • C Offline
                  charliwest
                  I tweaked the bash script to the api @krisalexroberts suggested as it takes a lot less to do it, and at @dinkybluebug245’s suggestion added the extra readings…although not sure how the pi will read the hex values? But it works on mac
                  USERNAME=you@your.email
                  curl --silent “https://my.tado.com/mobile/1.9/getCurrentState?username=“$USERNAME”&password=“$PASSWORD”” > temp
                  insideTemp=$(grep -o “insideTemp." temp| awk ‘{print substr($1,13,4)}’)
                  setPointTemp=$(grep -o "setPointTemp.
                  ” temp| awk ‘{print substr($1,15,4)}’)
                  heatingOn=$(if grep -q “"heatingOn":true” temp; then
                  echo ‘\xf0\x9f\x94\xa5’
                  else
                  echo ‘\xf0\x9f\x9a\xab’
                  fi)
                  echo “$insideTemp” / “$setPointTemp” / “$heatingOn”
                    @charliwest - so how does this all get written up as a magic mirror module? do you know?
                    • C Offline
                      charliwest
                      Yeah no idea about nodejs stuff, spoke to a friend today who is hoping to build a magicmirror (I still havent had time to set mine up at all). He is keen to have a look at this with me. We will hopefully sit down over a couple of beers next week and see if we can bash something out.
                      Anyone else who already knows more about modules happy for them to take the above and make it work…
                      @dinkybluebug245 did you test the above, even though only a bash script, still pretty cool
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @charliwest
                        @charliwest I would have some sparetime tonight, therefore I could help out if someone with a tado acc would like to join me
                        • K Offline
                          krisalexroberts @strawberry 3.141
                          @strawberry-3.141 i have availability tonight
                            dinkybluebug245 @krisalexroberts
                            @strawberry-3-141 - Hello - I can help over the weekend, and next week - evenings this week Im busy
                              would be great to get someone with other devices than a heating unit
                              D K 2 Replies Last reply Reply Quote 0
                                dinkybluebug245 @strawberry 3.141
                                @strawberry-3.141 can’t help with that. But if you need some else to test tado heating api. I can help.
                                • K Offline
                                  @strawberry-3.141 I’ll be getting radiator thermostats in the next few weeks but no cooling
                                    @charliwest This didnt work for me…
                                    I got this error:
                                    tado.sh: line 5: unexpected EOF while looking for matching `"’
                                    tado.sh: line 12: syntax error: unexpected end of file
                                    the contents of tado.sh, is:
                                    USERNAME=xxx
                                    PASSWORD=xxxx
                                    setPointTemp=$(grep -o "setPointTemp.” temp| awk ‘{print substr($1,15,4)}’)
                                    heatingOn=$(if grep -q ““heatingOn”:true” temp; then
                                    echo '\xf0\x9f\x94\xa5’
                                    else
                                    echo '\xf0\x9f\x9a\xab’
                                    fi)
                                    • C Offline
                                      charliwest
                                      @dinkybluebug245 probably a cut and paste error with the ticks, try from here https://github.com/charliwest/random_scripts/blob/master/tado2
                                        @charliwest Thanks for the response, I get a different error now,
                                        grep: temp: No such file or directory
                                        tado.sh: command substitution: line 16: syntax error near unexpected token fi' 'ado.sh: command substitution: line 16: fi)
                                        • C Offline
                                          charliwest @dinkybluebug245
                                          @dinkybluebug245 there shouldn’t be a line 16, can you double check the file u made is correct. Where are you running the script from? Also it says something about ado.sh … not sure what that’s referring to?
                                            @charliwest Yes you’re right… file wasnt created correctly.
                                            output now is
                                            20.5 / 10," / \xf0\x9f\x9a\xab
                                            seems to work, but your comment on how the pi would deal with hex values was right, and because the second value only has two digits (10) Im assuming this is why its picking up the characters ,"
