    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 117.6k Views 39 Watching
    • C Offline
      Cupola
      Dumb question, how do you exactly generate the access token? I’m a little bit confused…
      From pm2 logs, I read:
      ** Message: console message: http://localhost:8080/modules/MMM-Todoist//MMM-Todoist.js @199: SyntaxError: Unexpected token ‘>’
      I used the access token generated from here, but I’m not sure about the process, which App service URL did you use? Which OAuth redirect URL? And last which token is the right one? I can see three of them
      Thanks in advance
      pyrosmileyP 1 Reply Last reply Reply Quote 1
      • pyrosmileyP Offline
        pyrosmiley @Cupola
        @Cupola
        Not a dumb question, don’t worry! Oauth2 can be super confusing, and everyone does it a little differently which is… frustrating at best.
        The Access Token you need is the 3rd one, what they refer to as your Test Token on the page. (The idea behind this is that with OA2, each would-be client has to use its ID and Secret to ask for specific account access for each account it wants to see. They basically did that process for you once, for testing or personal things like this that only need your account.)
        You don’t need to worry about the OAuth redirect URL or the App Service URL. I have each filled with http://127.0.0.1 but I don’t think either are required at all.
        Hopefully this gets you up and running!
        • C Offline
          Cupola
          Thank you, now it’s working
            mariecbilodeau
            Is there a way to add bullets before each task?
              amomat
              Hi. Is it possible to show who the task is assigned to? Trying to set up a to-do list for the kids to show their chores.
              • eprostkoE Offline
                eprostko
                Todoist is working on my MM, but the day is not right. I have a daily recurring task that says “today” on my mirror, but is “tomorrow” when I look on todoist.com directly or on my phone app.
                Has anyone else seen and resolved this behavior?
                  Mariba
                  Hey,
                  is there functionality to see the number of days left for an event? I’d be happy if I could see that.
                  Or is it possible to show it myself by subtracting the date of the event from the current date? If yes, how do I do it?
                  Thanks. Happy New Year.
                    jani.karna
                    Hi! How can I get sorting working? No matter what I try, items are only added to the end of the list. I would like to sort them by priority and then by due date, but can’t figure of how.
                      Jas
                      For the OAuth, I can’t seem to find the “Test Token” on ToDoList site. Under the app, I only have Client ID and Client Secret. Under Settings/Integrations, there is a entry for API Token. Which of the 3 should I be using? Right now, I don’t have anything showing up from ToDoList when Mirror is running.
                      • C Offline
                        Clubjack @cbrooker
                        @cbrooker
                        Hey. I am using your Module.
                        Thank You for your work.
                        Do You think, its easy to change the Look?
                        I youse the Module “Mmm-my calendar”, and it would be great to have the same Look.
                        (two lines, one with Taskname, one with date, and a Symbol)
                        Mayve someone have an idea to realize that
                        • C Offline
                          Clubjack @Clubjack
                          Could one of the professionals take a look at the config of MMM-Todoist and MMM-myCalendar and see if it would be possible to easily adapt the look of mycalendar to that of todoist?
                          • C Offline
                            Clubjack
                            I must ask again.🙈
                            Could somebody help me to change the Look of MMM-Todoist?
                            It would be great, if the Look could be the same like MMM-myCalendar.
                            Then it would make a better overall impression.
                            At first, it would be great to know, if this is (easily) makebal.
                            • CynicC Offline
                              Cynic
                              Hello everyone! Need your help. Parameter: showProjects: false does not remove the project from the mirror. Where is the mistake?
                              I am not a wizard. I am just learning.
                              • cowboysdudeC Offline
                                cowboysdude Module Developer @Clubjack
                                @Clubjack said in MMM-Todoist - Your todoist tasks on your mirror:
                                I must ask again.🙈
                                You’d need to change the css and more then like the innerHTML’s themselves.
                                  banbutcher
                                  hi,
                                  ive just installed mmm-todoist on my mirror and after the install i can start the mirror fine but it seems that after its installed i think its affecting either mmm-keybindings of mmm-carousel because normally i can use the arrow keys to gleft and right BUT im not able to click on the page indicator to select a page, and after installing mmm-todoist im now not able to use arrow keys to select page BUT i am now able to click on the page indicator to select pages!! Curious!!
                                  i get no errors starting but in the development tools section im getting these warnings and errors:
                                  /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                                    protocols.This exposes users of this app to unnecessary security risks.
                                    Consider loading the following resources over HTTPS or FTPS.
                                   - http://0.0.0.0:8080/css/main.css
                                  - http://0.0.0.0:8080/fonts/roboto.css
                                  - http://0.0.0.0:8080/socket.io/socket.io.js
                                  - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                                  - http://0.0.0.0:8080/js/defaults.js
                                  - http://0.0.0.0:8080/config/config.js
                                  - http://0.0.0.0:8080/vendor/vendor.js
                                  - http://0.0.0.0:8080/modules/default/defaultmodules.js
                                  - http://0.0.0.0:8080/js/logger.js
                                  - http://0.0.0.0:8080/translations/translations.js
                                  - http://0.0.0.0:8080/js/translator.js
                                  - http://0.0.0.0:8080/js/class.js
                                  - http://0.0.0.0:8080/js/module.js
                                  - http://0.0.0.0:8080/js/loader.js
                                  - http://0.0.0.0:8080/js/socketclient.js
                                  - http://0.0.0.0:8080/js/main.js
                                  - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                                  - http://0.0.0.0:8080/translations/en.json
                                  - http://0.0.0.0:8080/modules/MMM-Carousel//MMM-Carousel.js
                                  - http://0.0.0.0:8080/modules/MMM-Carousel/MMM-Carousel.css
                                  - http://0.0.0.0:8080/modules/MMM-GoogleAssistant//MMM-GoogleAssistant.js
                                  - http://0.0.0.0:8080/modules/MMM-GoogleAssistant/components/response.js
                                  - http://0.0.0.0:8080/modules/MMM-GoogleAssistant/MMM-GoogleAssistant.css
                                  For more information and help, consult
                                  https://electronjs.org/docs/tutorial/security.
                                   This warning will not show up
                                  once the app is packaged.
                                  /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                                      Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                                  :8080/modules/MMM-Go…ib/highcharts.js:10 Uncaught Error: Highcharts error #16: www.highcharts.com/errors/16
                                      at Object.a.error (:8080/modules/MMM-Go…ib/highcharts.js:10)
                                      at :8080/modules/MMM-CO…lib/highcharts.js:8
                                  TypeError: Cannot read property 'items' of undefined
                                      at Class.getDom (:8080/modules/MMM-To…/MMM-Todoist.js:551)
                                      at main.js:111
                                      at new Promise (<anonymous>)
                                      at updateDom (main.js:110)
                                      at main.js:52
                                      at Array.forEach (<anonymous>)
                                      at createDomObjects (main.js:21)
                                      at Object.modulesStarted (main.js:499)
                                      at startModules (loader.js:56)
                                      at loader.js:38
                                  :8080/modules/MMM-To…/MMM-Todoist.js:551 Uncaught (in promise) TypeError: Cannot read property 'items' of undefined
                                      at main.js:111
                                      at main.js:52
                                      at loader.js:38
                                  api.openweathermap.o…ef566eab7f1c9b6c4:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                                  :8080/modules/defaul…therforecast.js:261 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                                  and my config is:
                                  /*-------------------- MMM-Todoist Route Start-----------------*/
                                  		module: 'MMM-Todoist',
                                  		position: 'top_left',
                                  		header: 'Todoski...',
                                  			hideWhenEmpty: true,
                                  			accessToken: 'xoxoxoxox',
                                  			maximumEntries: 60,
                                  			updateInterval: 10*60*1000, // Update every 10 minutes
                                  			fade: false,
                                  			// projects and/or labels is mandatory:
                                  			projects: [ xxxxxxx, xxxxxxx ],
                                  			//labels: [] // Tasks for any projects with these labels will be shown
                                  also but not a biggie, i have 2 projects todo and magicmirror after adding a couple to each, the mirror displays them in staggered project order rather than in order as added - ie:
                                  task1 - todo
                                  task5 - MM
                                  task2 - todo
                                  task6 -MM
                                  task3 - todo
                                  task7 - MM
                                  task4 - todo
                                  id like:
                                  task1 - todo
                                  task2 - todo
                                  task3 - todo
                                  task4 - todo
                                  task5 - MM
                                  task6 -MM
                                  task7 - MM
                                  any help or ideas would be great!
                                  Many thanks,
                                  Richie
                                  • edwardssjE Offline
                                    edwardssj @cbrooker
                                    @cbrooker Strange thing is happening here, when it refreshes the list at 10 minutes my mirror restarts, any suggestions?
                                    • 4 / 4
