    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 138.6k Views 25 Watching
    • yawnsY Offline
      yawns Moderator
      very interesting, I will try it this weekend. I’m just wondering why this is not documented on any forum or website, even though you can find several users with version mismatch issues.
      Great finding, @James
        samydp
        hello is not working!
        i have downgrade the node.js version from v6 to 5v and i dont now why i become a white screen.
        my pm2 logs
        [TAILING] Tailing last 10 lines for [all] processes (change the value with --lin        es option)
        /home/pi/.pm2/pm2.log last 10 lines:
        PM2        | 2016-09-21 20:18:32: Starting execution sequence in -fork mode- for        app name:mm id:0
        PM2        | 2016-09-21 20:18:32: App name:mm id:0 online
        PM2        | 2016-09-21 20:21:28: Stopping app:mm id:0
        PM2        | 2016-09-21 20:21:28: App [mm] with id [0] and pid [1071], exited wi        th code [0] via signal [SIGINT]
        PM2        | 2016-09-21 20:21:28: Starting execution sequence in -fork mode- for        app name:mm id:0
        PM2        | 2016-09-21 20:21:28: App name:mm id:0 online
        PM2        | 2016-09-21 20:24:05: Stopping app:mm id:0
        PM2        | 2016-09-21 20:24:06: App [mm] with id [0] and pid [1250], exited wi        th code [0] via signal [SIGINT]
        PM2        | 2016-09-21 20:24:06: Starting execution sequence in -fork mode- for        app name:mm id:0
        PM2        | 2016-09-21 20:24:06: App name:mm id:0 online
        /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
        0|mm       | No helper found for module: alert.
        0|mm       | No helper found for module: clock.
        0|mm       | Initializing new module helper ...
        0|mm       | No helper found for module: compliments.
        0|mm       | No helper found for module: currentweather.
        0|mm       | No helper found for module: weatherforecast.
        0|mm       | Whoops! There was an uncaught exception...
        0|mm       | MagicMirror will not quit, but it might be a good idea to check why        this happened. Maybe no internet connection?
        0|mm       | If you think this really is an issue, please open an issue on GitHu        b: https://github.com/MichMich/MagicMirror/issues
        0|mm       | Launching application.
        /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
        0|mm       |     at Error (native)
        0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_AS        AR.js:168:20)
        0|mm       |     at Object.Module._extensions..node (module.js:583:18)
        0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR        .js:168:20)
        0|mm       |     at Module.load (module.js:473:32)
        0|mm       |     at tryModuleLoad (module.js:432:12)
        0|mm       |     at Function.Module._load (module.js:424:3)
        0|mm       |     at Module.require (module.js:483:17)
        0|mm       |     at require (internal/module.js:20:19)
        0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_m        odules/bindings/bindings.js:76:44)
        Note from admin: Please use Markdown on code snippets for easier reading!
        • BangeeB Offline
          Bangee Module Developer
          @samydp did you maybe reneamed this folder:
          modules/MMM-PIR-Sensor/node_m odules <- is there a space in this name??
          you’ll have to remove this
            samydp
            I have the folder node_modules in MMM-Pir folder .
            should I delete the folder?
            • BangeeB Offline
              Can you post a printscrenn from this folder?
              you can also try to go use these commands:
              cd ~/MagicMirror/modules/MMM-PIR-Sensor/
              git pull
              npm rebuild
                samydp
                • BangeeB Offline
                  That looks fine.
                  Did you try to remove your folder MMM-PIR-Sensor an reinstall the modul?
                    samydp
                    yes but i dont have the folder node_modules in the PIR Folder :/ i have install WrinPi but nothing works :/
                    • BangeeB Offline
                      ok so lets go step by step:
                      now we will remove the PIR folder:
                      rm -rf MMM-PIR-Sensor
                      and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                      git clone https://github.com/paviro/MMM-PIR-Sensor.git
                      cd MMM-PIR-Sensor
                      run the following cmd here:
                      npm install and wait, this can take a few minutes.
                      Now you’ll have to add pi to gpio
                      sudo useradd -g pi gpio
                      and reboot your Raspi:
                      sudo reboot
                      You’ll have to connect your PIR Sensor the right way with your Raspi.
                      I’ve connected my PIR Sensor on the following Pins:
                      GPIO
                      I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
                      – correctin grn pin
                      PIR Sensor
                      and dont forget to add the config :-)
                      D 1 Reply Last reply Reply Quote 3
                        samydp
                        you are the best !! i dont become no a with screen !
                        but the sensor dont work
                        i have
                        vcc: Pin 2
                        Data: Pin 7
                        Ground: Pin 6
                        and my config in the config and MMM-PIR-Sensor data is:
                                		module: 'MMM-PIR-Sensor',
                        			sensorPIN: 7,
                        			relayPIN: false,
                        			powerSaving: true,
                        			relayOnState: 1,
                        the sensetiv is max and the time is min
                        • 6
                        • 7
                        • 8
                        • 9
                        • 4 / 9
