Possible sytax error in my config.js file?
5 Posts 4 Posters 1.6k Views 2 Watching
    BenPoulson
    (Resubmitted to remove personal info) I’m probably just an idiot, but I can’t figure out what my syntax error is here. Does someone else see it?
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config = {
            port: 8080,
            language: "en",
            timeFormat: 24,
            units: "imperial",
                            module: "alert",
                            module: "updatenotification",
                            position: "top_bar"
                            module: "clock",
                            position: "top_left"
                            header: "Family Calendar",
                                                    symbol: "calendar-check-o ",
                                                    url: "MY CALENDAR URL"
                            module: "compliments",
                            position: "lower_third"
                                    updateInterval: 30000,
                                    compliments: {
                                            morning: [
                                                    "Good morning, sunshine!",
                                                    "Looking good!",
                                                    "Go get em!",
                                                    "You look great!",
                                                    "Perfect circle!",
                                                    "I bet you do the crossword in ink.",
                                                    "You're more fun than bubble wrap!"
                                            afternoon: [
                                                    "What a gorgeous day!",
                                                    "Looking good!",
                                                    "Go get em!",
                                                    "You look great!",
                                                    "Perfect circle!",
                                            evening: [
                                                    "It was such a great day!"
                                                    "Looking good!",
                                                    "Go get em!",
                                                    "You look great!",
                                                    "Perfect circle!",
                            module: "currentweather",
                                    locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                    appid: "YOUR_OPENWEATHER_API_KEY"
                            module: "weatherforecast",
                            header: "Weather Forecast",
                                    locationID: "5422503",  //ID from http://www.openweathermap.org/help/city_list.txt
                                    appid: "87ef9f3a1f3d7e4738344c85226dfd00"
                            module: "newsfeed",
                            position: "bottom_bar",
                                    feeds: [
                                                    title: "New York Times",
                                    showSourceTitle: true,
                                    showPublishDate: true
      barnosch
      Since there isn’t yet so much “customized” stuff in there, i would suggest, you start again with the dummy file provided in the /config folder.
      Then add the first module, if this is working then, add the second… and so on.
      Otherwise you will go crazy.
      • Y Offline
        yawns Moderator
        Your problems are with the compliments module. You are missing a comma after position: "lower_third" and another comma after "It was such a great day!" in the evening array.
        B 1 Reply Last reply Dec 13, 2017, 4:04 PM Reply Quote 2
        • C Offline
          cowboysdude Module Developer
          Valid
           * MIT Licensed.
          var config = {
                  port: 8080,
                  language: "en",
                  timeFormat: 24,
                  units: "imperial",
                                  module: "alert",
                                  position: "top_bar"
                                  module: "clock",
                                  position: "lower_third",
                                          compliments: {
                                                  morning: [
                                                          "Looking good!",
                                                          "Go get em!",
                                                          "You look great!",
                                                          "Perfect circle!",
                                                  afternoon: [
                                                          "Looking good!",
                                                          "Go get em!",
                                                          "You look great!",
                                                          "Perfect circle!",
                                                  evening: [
                                                          "It was such a great day!",
                                                          "Looking good!",
                                                          "Go get em!",
                                                          "You look great!",
                                                          "Perfect circle!",
                                  module: "newsfeed",
                                          feeds: [
            BenPoulson @yawns
            @yawns That was it, thanks!
