    Auto-Start Failed
    4 Posts 3 Posters 2.7k Views 3 Watching
      jaerenull
      Hey so I’m having trouble auto-starting my magic mirror.
      I used this guide:
      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
      And followed it line by line.
      That being said, I dug through the forums and it seems like people were having trouble doing this in the older versions of MM but I couldn’t find anything current.
      This is what I’ve been getting. It looks fine, but the mm.sh file just doesn’t actually execute on startup. I have to manually enter
      pm2 start mm.sh
      to get the MM to actually start.
      Any help with this?
      Thanks!
        Mykle1 Project Sponsor Module Developer @jaerenull
        @jaerenull
        It doesn’t seem as if you executed the command circled in red.
          jaerenull
          So I went back and ran that sudo command.
          pi@raspberrypi:~/MagicMirror $ pm2 startup
          [PM2] Init System found: systemd
          [PM2] To setup the Startup Script, copy/paste the following command:
          sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
          pi@raspberrypi:~/MagicMirror $ sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
          Platform systemd
          Template
          [Unit]
          Description=PM2 process manager
          Documentation=https://pm2.keymetrics.io/
          After=network.target
          [Service]
          Type=forking
          User=pi
          LimitNOFILE=infinity
          LimitNPROC=infinity
          LimitCORE=infinity
          Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
          Environment=PM2_HOME=/home/pi
          PIDFile=/home/pi/pm2.pid
          ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
          ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
          ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
          [Install]
          WantedBy=multi-user.target
          Target path
          /etc/systemd/system/pm2-pi.service
          Command list
          [ ‘systemctl enable pm2-pi’,
          ‘systemctl start pm2-pi’,
          ‘systemctl daemon-reload’,
          ‘systemctl status pm2-pi’ ]
          [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
          [PM2] Making script booting at startup…
          Executing systemctl enable pm2-pi
          [DONE]
          Executing systemctl start pm2-pi
          [DONE]
          Executing systemctl daemon-reload
          [DONE]
          Executing systemctl status pm2-pi
          ● pm2-pi.service - PM2 process manager
          Loaded: loaded (/etc/systemd/system/pm2-pi.service; enabled; vendor preset: enabled)
          Active: active (running) since Thu 2017-12-14 16:59:48 CST; 6min ago
          Docs: https://pm2.keymetrics.io/
          Main PID: 640 (PM2 v2.9.0: God)
          CGroup: /system.slice/pm2-pi.service
          └─640 PM2 v2.9.0: God Daemon (/home/pi)
          Dec 14 16:59:48 raspberrypi pm2[425]: [PM2] Restoring processes located in /home/pi/dump.pm2
          Dec 14 16:59:48 raspberrypi pm2[425]: [PM2][ERROR] Failed to read dump file in /home/pi/dump.pm2
          Dec 14 16:59:48 raspberrypi pm2[425]: [PM2][ERROR] Failed to read dump file in /home/pi/dump.pm2.bak
          Dec 14 16:59:48 raspberrypi pm2[425]: [PM2][ERROR] No processes saved; DUMP file doesn’t exist
          Dec 14 16:59:48 raspberrypi pm2[425]: ┌──────────┬────┬──────┬─────┬────────┬─────────┬────────┬─────┬─────┬──────┬──────────┐
          Dec 14 16:59:48 raspberrypi pm2[425]: │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
          Dec 14 16:59:48 raspberrypi pm2[425]: └──────────┴────┴──────┴─────┴────────┴─────────┴────────┴─────┴─────┴──────┴──────────┘
          Dec 14 16:59:48 raspberrypi pm2[425]: Use pm2 show to get more details about an app
          Dec 14 16:59:48 raspberrypi systemd[1]: Started PM2 process manager.
          [DONE]
          [PM2] Freeze a process list on reboot via:
          $ pm2 save
          [PM2] Remove init script via:
          $ pm2 unstartup systemd
          pi@raspberrypi:~/MagicMirror $ pm2 save
          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
          [PM2] PM2 Successfully daemonized
          [PM2] Saving current process list…
          [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
          pi@raspberrypi:~/MagicMirror $ cd ~
          pi@raspberrypi:~ $ nano mm.sh
          pi@raspberrypi:~ $ chmod +x mm.sh
          pi@raspberrypi:~ $ pm2 start mm.sh
          [PM2] Starting /home/pi/mm.sh in fork_mode (1 instance)
          [PM2] Done.
          │ mm │ 0 │ fork │ 1304 │ online │ 0 │ 0s │ 2% │ 2.6 MB │ pi │ disabled │
          pi@raspberrypi:~ $ pm2 save
          pi@raspberrypi:~ $ sudo reboot
          and nothing happened still…any thoughts/suggestions?
          • H Offline
            hawkeyepilot69 @jaerenull
            @jaerenull
            any update? this is what mine is currently doing.
