    "No Syntax Errors" but "Could noch validate config.file"
    3 Posts 2 Posters 2.2k Views 2 Watching
    • K Offline
      killing joke
      Hello there,
      I´m trying to configure my MagicMirror but unfortunately I´m completly new in this (Raspberry Pi coding).
      I installed everything according to the manual from the MagicMirror homepage and it worked fine as default.
      Afterthat I wanted to customize everything (my city for weather, calender/holidays for Germany, etc.), but thats where I´m stucked.
      I changed the “config/config.js”-file (according to the MagicMirror homepage) and had some syntax errors.
      Therefore I checked the internet and found a how-to “emilinate syntax errors for beginners” and I fixed everything and checked it with “npm run config:check” and it said “Your configuration file don´t containt syntax error :)” but when I want to start the npm I got a warning "WARNING! Could not validate config file. Please correct syntax errors. ".
      My Problem are:
      • I don´t know how procede with the troubleshooting
      • I don´t know how to transfer a config-file from a Raspberry Pi to a Windows 10 Computer (Remotedesktop / putty)
      I would appreciate if someone could help me.
      Best Regards
      Daniel
        Mykle1 Project Sponsor Module Developer @killing joke
        @killing-joke said in “No Syntax Errors” but “Could noch validate config.file”:
        You could start here. Start with the default config again. When that is running add one module at a time using this guide
        https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
        • K Offline
          killing joke
          Hi Mykle1,
          thanks for answering.
          I didn´t add any modules yet. Only the default modules.
          I will try that. Thanks for your help.
