    first attempt .. gone wrong :)
    9 Posts 4 Posters 4.2k Views 2 Watching
      davide
      Hi !
      I’m just approaching to this nice project.
      So, I tried the automatic installation on my Raspberry 2 running his standard rasbian os … But it’s failing again and again
      Basically the script starts saying a lot of
       warn tar ENOENT: no such file or directory, open
      you can find the whole code as an attachment
      …basically I don’t how to solve or debug this … Could someone kindly provide some help ? Thanks!!
      [0_1515270113017_2018-01-06T19_53_09_683Z-debug.7z](Uploading 100%)
        davide
        I don’t know why I can’t upload code here … anyway, you can find it in pastebin
        • Y Offline
          yawns Moderator
          Did you run the installation with sudo? It’s trying to install in /root/MagicMirror and that’s wrong
          • cowboysdudeC Offline
            cowboysdude Module Developer
            Do the manual install and don’t use SUDO… :)
              davide
              even executing it as root it is failing …and also manual installation it’s faling.
              maybe the reason is very simple : it’s because I’m using rasbian server version ? Should I use raspbian with desktop enviroment ?
                Not sure about the version but I would just install plain old raspbian and try it again.
                • cruunnerrC Offline
                  cruunnerr
                  To be sure everything will work fine i would use the desktop version. Best option here is Jesse i think :)
                  Otherwise u can try this guide, cause with the lite versions of raspbian there are dependancies missing for the MagicMirror.
                  The guide works fine for me using raspbian stretch lite
                    davide
                    ohh wow! that’s exactly what I was looking for … Thank you a lot! I will let you know if everything is ok!
                      davide
                      finally here’s the solution :
                      as mentioned here, you should use this command for installation :
                      npm install --unsafe-perm=true
                      and now installation is succesfull!
