first attempt .. gone wrong :)
9 Posts 4 Posters 3.2k Views 2 Watching
    davide
    Hi !
    I’m just approaching to this nice project.
    So, I tried the automatic installation on my Raspberry 2 running his standard rasbian os … But it’s failing again and again
    Basically the script starts saying a lot of
     warn tar ENOENT: no such file or directory, open [...]
    you can find the whole code as an attachment
    …basically I don’t how to solve or debug this … Could someone kindly provide some help ? Thanks!!
    [0_1515270113017_2018-01-06T19_53_09_683Z-debug.7z](Uploading 100%)
      davide
      I don’t know why I can’t upload code here … anyway, you can find it in pastebin
      • Y Offline
        yawns Moderator
        Did you run the installation with sudo? It’s trying to install in /root/MagicMirror and that’s wrong
          Do the manual install and don’t use SUDO… :)
            davide
            even executing it as root it is failing …and also manual installation it’s faling.
            maybe the reason is very simple : it’s because I’m using rasbian server version ? Should I use raspbian with desktop enviroment ?
              Not sure about the version but I would just install plain old raspbian and try it again.
                cruunnerr
                To be sure everything will work fine i would use the desktop version. Best option here is Jesse i think :)
                Otherwise u can try this guide, cause with the lite versions of raspbian there are dependancies missing for the MagicMirror.
                The guide works fine for me using raspbian stretch lite
                  davide
                  ohh wow! that’s exactly what I was looking for … Thank you a lot! I will let you know if everything is ok!
                    davide
                    finally here’s the solution :
                    as mentioned here, you should use this command for installation :
                    npm install --unsafe-perm=true
                    and now installation is succesfull!
