first attempt .. gone wrong :)
Hi !
I’m just approaching to this nice project.
So, I tried the automatic installation on my Raspberry 2 running his standard rasbian os … But it’s failing again and again
Basically the script starts saying a lot ofwarn tar ENOENT: no such file or directory, openyou can find the whole code as an attachment
…basically I don’t how to solve or debug this … Could someone kindly provide some help ? Thanks!!
[0_1515270113017_2018-01-06T19_53_09_683Z-debug.7z](Uploading 100%) -
I don’t know why I can’t upload code here … anyway, you can find it in pastebin
Did you run the installation with sudo? It’s trying to install in /root/MagicMirror and that’s wrong
Do the manual install and don’t use SUDO… :)
even executing it as root it is failing …and also manual installation it’s faling.
maybe the reason is very simple : it’s because I’m using rasbian server version ? Should I use raspbian with desktop enviroment ? -
Not sure about the version but I would just install plain old raspbian and try it again.
To be sure everything will work fine i would use the desktop version. Best option here is Jesse i think :)
Otherwise u can try this guide, cause with the lite versions of raspbian there are dependancies missing for the MagicMirror.
The guide works fine for me using raspbian stretch lite -
ohh wow! that’s exactly what I was looking for … Thank you a lot! I will let you know if everything is ok!
finally here’s the solution :
as mentioned here, you should use this command for installation :npm install --unsafe-perm=trueand now installation is succesfull!
