    MMM-WienerLinien
    wienviennapublic transportöpnvwienerlinien
    16 Posts 4 Posters 13.4k Views 4 Watching
    • strawberry 3.141S Offline
      alt text
      alt text
      [card:fewieden/MMM-WienerLinien]
        spedja
        Hi fewieden!
        first off all, thanks for this module, will be very useful for Viennese people.
        I found small issue with the module. Seems, response from WienerLinien is not the same for all types of transport.
        Check response for RBL: 4414 vs 199
        therefore module gets bigger (size-wise) and displays a result in one row (+ overlapping with calendar):
        Thanks!
          strawberry 3.141 Project Sponsor Module Developer @spedja
          @spedja I experienced the different results as well. I don’t know why, but for every metro station I tried, I got no departureTimes at all, so I guess you can used it for bus and tram only. Maybe the metro has no departureTimes because they drive so often, therefore an API documentation would be nice
            spedja @strawberry 3.141
            @strawberry-3.141 i found API documentation but its in German
            http://data.wien.gv.at/pdf/wienerlinien-echtzeitdaten-dokumentation.pdf
            strawberry 3.141S 2 Replies Last reply Reply Quote 0
              @spedja nice timing :) I received my API token this afternoon, will look into this the next days and hopefully can get around the metro problem
                @spedja I couldn’t find any information about this in the documentation, but with further investigation I stumbled on this http://www.offene-oeffis.at/faqs/warum-erhalte-ich-manchmal-etwas-wie-u1-leopoldau-in-x-minuten-als-string-in-towards-statt-als-departure/, so i guess in your screenshot is the departure of the metro in 2 and 5 mins, if so i have to handle those special
                EDIT: should be fixed now
                  @strawberry-3.141 Yes it works! You are the man! Thank you.
                    Beryllium30
                    Is it possible to show routes between two stations? I can’t find anything in the documentation.
                    Really appreciate the module!
                      Dom1n1c
                      There is another API available.
                      Why don’t you use the EFA (From Elektronische Fahrplanauskunft)
                      It’s the biggest Provider in the market (Mentz Datenverarbeitung)
                      It includes realtime information and shows routes:
                      http://data.wien.gv.at/pdf/wiener-linien-routing.pdf
                      It is available for several transportation companies/communities in Germany, UK and so on.
                        strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
                        @Dom1n1c I didn’t make a research for available API’s, I just took the one I got from the user who requested the module.
                          Two new config options to limit size of the station and destination name
                            Beryllium30
                            Anyone else have it stuck at loading?
                              Changelog:
                              • it is now possible to get informed about elevator and line incidents thanks to @flo80 for his contribution
                                Version 2 is released
                                • API key no longer required
                                • Fix Config option incidentShort.
                                • Dependency updates
                                • Nunjuck templates
                                • and more …
                                How to update
                                Make sure you run cd ~/MagicMirror/modules/MMM-WienerLinien ; git pull ; npm i --production, as I replaced dependencies.
                                https://github.com/fewieden/MMM-WienerLinien
                                  The API provider has fixed an issue on their side, so config option incidentShort: false is filtering correctly again.
                                    Version 2.0.1
                                    Fixed
                                    • Sorting of departure times https://github.com/fewieden/MMM-WienerLinien/issues/16
