    npm start dev
    13 Posts 5 Posters 16.1k Views 4 Watching
      Bangee Module Developer
      Hi there
      I try to start my mirror whit npm start dev to do some debugging but there are always a lot of errors. What’s wrong here?
      pi@raspberrypi:~/MagicMirror $ npm start dev
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js "dev"
      npm ERR! Linux 4.4.13-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "dev"
      npm ERR! node v6.4.0
      npm ERR! npm  v3.10.3
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js "dev"
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
        shavesophere
        Hi Bangee
        I’ve had exactly the same problem. I’ve tried it on a rasp 2, a rasp 3 and still the same result. Tried reinstalling node.js, reinstalling npm. I’m beginning to think there’s something up with Mich;s installation script but I cant find any clues in the output. Apparently it’s known that sometimes electron will fail on some rasp 2’s- so i went ou t and bought a rasp 3. I’m currently trying it again on a new card - if it doesn’t work this time i’ll try the manual install method. No luck yet.
        pi@magicpi:~ $ cd MagicMirror/config
        pi@magicpi:~/MagicMirror/config $ cp config.js.sample config.js
        pi@magicpi:~/MagicMirror/config $ cd $HOME/MagicMirror
        pi@magicpi:~/MagicMirror $ npm start
        npm ERR! Linux 4.4.11-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.6.0
        npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
        npm ERR!
        npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
        Note from admin: Please use Markdown on code snippets for easier reading!
        • O Offline
          ostfilinchen
          Hey!
          in the readme i found this:
          Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
            shavesophere
            Thanks ost - but I have tried it both from direct physical keyboard and SSH using this command. I’ve been reading a few other problems related to this issue but all seems to come down to “not installing as root user”. Which i’m not - I’m installing as pi. So still scratching my head here.
            • O Offline
              ostfilinchen
              do you have create an mm.sh and starts this with pm2?
                shavesophere @ostfilinchen
                @ostfilinchen I was just using the standard install script that comes on the tutorial.
                curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                • O Offline
                  ostfilinchen
                  and do u do these steps: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                    hey there
                    @ostfilinchen that’s it. to start npm from my shell it need to use this command:
                    DISPLAY=:0 npm start dev
                    But with this I can not debug my script. Electron crashes alwasy on startup when I’ve activated my new module using const sensorLib = require('node-dht-sensor') in my node_helper.js
                    How can I debug this error?
                      shavesophere
                      OK i think i’ve solved it. magic mirror HAS to be started (npm start) from a terminal window in the x-window server. you cannot start it over ssh.
                      B K 2 Replies Last reply Reply Quote 1
                        bhepler Module Developer @shavesophere
                        @shavesophere Thank you. This at least got me to the point where I can show the display on a monitor. Now I just have to walk to the other room to see my changes. :/
                        • K Offline
                          KirAsh4 Moderator @shavesophere
                          @shavesophere said in npm start dev:
                          Not true. It can be started over SSH just fine: DISPLAY=:0 npm start
                            shavesophere @KirAsh4
                            @KirAsh4 sorry - i stand corrected! but that being said when i first started getting npm ERRS i tried this and it still did not work… anyway, moving forward now!
                            • K Offline
                              Well yeah, that’s different. If npm is giving you errors, no matter how you attempt to start it, the errors won’t magically go away. That’s like saying, the car won’t start if I’m sitting on the left side, maybe if I sit on the right side it might, but in reality there’s no gas in it. Switching seats isn’t going to fill the gas tank. :)
