    npm start dev
    13 Posts 5 Posters 15.2k Views 4 Watching
    • BangeeB Offline
      Bangee Module Developer
      Hi there
      I try to start my mirror whit npm start dev to do some debugging but there are always a lot of errors. What’s wrong here?
      pi@raspberrypi:~/MagicMirror $ npm start dev
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js "dev"
      npm ERR! Linux 4.4.13-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "dev"
      npm ERR! node v6.4.0
      npm ERR! npm  v3.10.3
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js "dev"
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
        shavesophere
        Hi Bangee
        I’ve had exactly the same problem. I’ve tried it on a rasp 2, a rasp 3 and still the same result. Tried reinstalling node.js, reinstalling npm. I’m beginning to think there’s something up with Mich;s installation script but I cant find any clues in the output. Apparently it’s known that sometimes electron will fail on some rasp 2’s- so i went ou t and bought a rasp 3. I’m currently trying it again on a new card - if it doesn’t work this time i’ll try the manual install method. No luck yet.
        pi@magicpi:~ $ cd MagicMirror/config
        pi@magicpi:~/MagicMirror/config $ cp config.js.sample config.js
        pi@magicpi:~/MagicMirror/config $ cd $HOME/MagicMirror
        pi@magicpi:~/MagicMirror $ npm start
        npm ERR! Linux 4.4.11-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.6.0
        npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
        npm ERR!
        npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
        • O Offline
          ostfilinchen
          Hey!
          in the readme i found this:
          Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
            shavesophere
            Thanks ost - but I have tried it both from direct physical keyboard and SSH using this command. I’ve been reading a few other problems related to this issue but all seems to come down to “not installing as root user”. Which i’m not - I’m installing as pi. So still scratching my head here.
            • O Offline
              ostfilinchen
              do you have create an mm.sh and starts this with pm2?
                shavesophere @ostfilinchen
                @ostfilinchen I was just using the standard install script that comes on the tutorial.
                curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                • O Offline
                  ostfilinchen
                  and do u do these steps: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                  • BangeeB Offline
                    hey there
                    @ostfilinchen that’s it. to start npm from my shell it need to use this command:
                    DISPLAY=:0 npm start dev
                    But with this I can not debug my script. Electron crashes alwasy on startup when I’ve activated my new module using const sensorLib = require('node-dht-sensor') in my node_helper.js
                    How can I debug this error?
                      shavesophere
                      OK i think i’ve solved it. magic mirror HAS to be started (npm start) from a terminal window in the x-window server. you cannot start it over ssh.
                      bheplerB KirAsh4K 2 Replies Last reply Reply Quote 1
                      • bheplerB Offline
                        bhepler Module Developer @shavesophere
                        @shavesophere Thank you. This at least got me to the point where I can show the display on a monitor. Now I just have to walk to the other room to see my changes. :/
