    Blank Screen on Pi 1 after successful Install
    21 Posts 7 Posters 17.4k Views 7 Watching
      bharathvenkat
      I have a Raspberry Pi 1. MM2 is successfully installed. i get a blank black screen after node serveronly start. I’m using the default config file from the update.
      apt-get update and apt-get upgrade - done
      git pull - done
      Updated local to US, timezone to Pacific.
      In the config file, I changed the language from en to en-us and blank without any success.
      Any help will be greatly appreciated.
      • Mr.MeeseeksM Offline
        Mr.Meeseeks
        Are you able to see if there is any js/console errors? (I’m new myself) perhaps view on another computer on the network?
        CAAAAN DOO!👍
        • P Offline
          pagoa
          Have you tried accessing the MM-interface on an other device? So if you enter “http://IP_OF_YOUR_PI:8080” in the browser of your computer for instance, does it work? I had a similar problem, where the interface only worked on other devices…
          But you know that electron is not working on the RPi 1 right? So you will probably have a hard time trying to get this to work yourself on a Pi1…
            BenRoe Module Developer
            @bharathvenkat i use MM with node serveronly and a Midori Browser on my Raspberry PI B. Theoretically it should work on your RPi. Like Mr.Meeseeks (btw rick and morty is awesome) proposed, open the developer console in the browser and check if there is some code.
            @pagoa he is using node serveronly. With this command electron is not used.
            • C Offline
              chase
              I’m also having this issue. I was getting the intro/setup your config screen. I got the donfig setup and wrestled with file permissions to get it copied. Relaunched and now I’ve got a black screen. The source of the page has the Magic Mirror stuff in it. Don’t know what’s wrong. Any advice?
              Mr.MeeseeksM 1 Reply Last reply Reply Quote 0
                Mr.Meeseeks @chase
                @chase what pi version? Are you running it in server mode? Any JavaScript errors in console? What browser?
                CAAAAN DOO!👍
                • C Offline
                  chase
                  I’m using an original model A. It is running in server mode, no javascript errors besides one below the don’t edit line in the config file. Any browser. Tried from multiple devices including the Pi itself. Thanks!
                    Which node.js Version is installed? Maybe this is the problem.
                    • C Offline
                      chase
                      v0.10.29
                        Try a newer node version.
                        Here is a blog post (unfortunately  in german) how to install the latest version. Deinstall the node before you install the newer version.
                        http://www.benjaminroesner.com/blog/node-js-raspberry-pi-installieren/#variante2
                        • 1 / 3
