    ECONNREFUSED when trying to get JSON from my server (MMM-json-feed)
    10 Posts 4 Posters 2.9k Views 3 Watching
    • T Offline
      toh1000
      Hi all,
      I like to display a simple value that can be fetched from a JSON service. So I started with the MMM-json-feed module which is pretty much doing the trick with some test services that I found (e.g. http://ip.jsontest.com/).
      It seemed to need just a simple adaptation of the config file, to load the JSON data from an URL in my private network.
      Unfortunately this does not work, although my JSON service returns proper data (checked with my browser). The mm output is
      MMM-json-feed sending request: GET http://raspberrypi.fritz.box/temp/
      MMM-json-feed received
      MMM-json-feed Error: connect ECONNREFUSED 192.168.178.33:80
      TypeError: Cannot read property 'statusCode' of undefined
          at Request._callback (/home/pi/MagicMirror/modules/MMM-json-feed/node_helper.js:15:48)
          at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
          at emitOne (events.js:96:13)
          at Request.emit (events.js:191:7)
          at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:878:8)
          at ClientRequest.emit (events.js:191:7)
          at Socket.socketErrorListener (_http_client.js:358:9)
          at Socket.emit (events.js:191:7)
      I thought it might relate to CORS and compared the headers of the JSONTest (http://ip.jsontest.com) and my JSON service. They both look quite similar. Nothing that make me believe there is something missing.
      JSONTest:
      Access-Control-Allow-Origin: *
      Cache-Control: private
      Content-Encoding: gzip
      Content-Length: 67
      Content-Type: application/json; charset=ISO-8859-1
      Date: Wed, 21 Feb 2018 21:08:30 GMT
      Server: Google Frontend
      Vary: Accept-Encoding
      X-Cloud-Trace-Context: f1d4981eae5655f530221b705a794f51
      Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
      Accept-Encoding: gzip, deflate
      Accept-Language: de,en-US;q=0.7,en;q=0.3
      Connection: keep-alive
      Host: ip.jsontest.com
      Upgrade-Insecure-Requests: 1
      User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:58.0) Gecko/20100101 Firefox/58.0
      My service:
      Content-Length: 64
      Date: Wed, 21 Feb 2018 21:08:06 GMT
      Server: CherryPy/13.1.0
      Cache-Control: max-age=0
      Host: raspberrypi.fritz.box
      Any guesses?
      • E Offline
        E3V3A @toh1000
        @toh1000 Please post JSON response. I just spent a day trying to figure out why MM is so fickly regarding non-perfect JSON being sent over the socket. Loading JSON from a variable, just fine. Pushing the exact same JSON over a socket…had problems.
        BTW. Is it correct that it says your JSON is GZIP encoded, no??
        "Everything I do (here) is for free – altruism is the way!"
        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
        N 2 Replies Last reply Reply Quote 0
        • N Offline
          ninjabreadman @E3V3A
          @toh1000 Can you reach the JSON service with curl on your MM machine? And @e3v3a is right – ideally put the response through a validator, especially for things like trailing commas.
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          • N Offline
            @E3V3A Also, @toh1000’s HTTP request included the header Accept-Encoding: gzip, deflate, so the test site responded with Content-Encoding: gzip. That’s totally appropriate, and usually this is handled transparently by the client, which will then provide the uncompressed response. However, the actual service (“My service”) responded with no compression.
            • E Offline
              E3V3A
              From here:
              ECONNREFUSED (Connection refused): No connection could be made because the target machine
              actively refused it. This usually results from trying to connect to a service that is inactive on the
              foreign host.
              • cowboysdudeC Offline
                cowboysdude Module Developer
                Here’s an example in my node helper I use to get json
                request({
                            url: "xxxxxxxxxxxx.json",
                            method: 'GET',
                            headers: {
                                'User-Agent': 'MagicMirror/1.0 (' + this.config.email + ')'
                T 1 Reply Last reply Reply Quote 1
                • T Offline
                  toh1000 @ninjabreadman
                  @ninjabreadman Yes, curl call returns correct json:
                  {"Date": "22.02.2018", "Temperature": -0.187, "Time": "22:45:37"}
                  • T Offline
                    toh1000 @E3V3A
                    @E3V3A Any idea what I could do to accept the connection?
                    • T Offline
                      toh1000 @cowboysdude
                      @cowboysdude I added the header (without the this.config.email) but got the same result.
                      • T Offline
                        toh1000
                        Solved:
                        The problem was that the module translated the server name into an up address and CherryPy was not configured to response to that.
                        Reconfiguring did the trick:
                        this article explains how this is done
                        Thanks for your efforts.
