    Touch screen over two way mirror
    48 Posts 20 Posters 52.9k Views 19 Watching
    • L Offline
      l8kerjuan @AlessandroRa
      @AlessandroRa could you post a link to item you purchased?
        r0mantic0
        I asked the company infotronik for the touch foil, the answer was:
        the problem with the touch foil: the mirror contain metalic components which would cause problems using the touch foil
        the problem with the IR frame is that it can’t be used behind the mirror
        so i thing the best solution would be the IR frame… but in some forums I was reading also that with the mirror can be used either a touch foil or the IR frame… hmmm, now I am confused
        • brobergB Offline
          broberg Project Sponsor @r0mantic0
          @r0mantic0 Haven’t thought about that at all, so had to try it, and they are indeed correct, the metal coating in the mirror acts as a conductor and anywhere you touch on the mirror gets amplified over the entire area. And thus renders the touchfoil useless.
          Crap.
          Need a new solution for my own mirror now.
          • cowboysdudeC Offline
            cowboysdude Module Developer @AlessandroRa
            @AlessandroRa said in Touch screen over two way mirror:
            I’m still working on my mirror, but I’ve bought a IR frame from aliexpress and it works good!
            Which size did you get?
            • 1m21 Offline
              1m2
              Anyone have a forum or link for the photobooth builds?
              This would also be so fun to build and have but on the coding side I’m no expert. On every thing else I’m handy enough to find solutions I think.
                cowboysdude Module Developer @1m2
                @1m2 Look up to the top and ask that guy… he wanted one too… maybe he found a way.
                  Marko
                  is anybody solve the problem with foil behind mirror? I asked several company’s for info and thay tell me that Projected capacitive will be the best sollution but miror may not contain metal inside. Is thare mirror / glass that is good to use with foil which does not create interference?
                  Is somebody succeed with this?
                    spacevolt @Marko
                    @Marko I would also like to know what type of two way mirror is best for PCAP foils/screens!
                    • H Offline
                      Hoosierdad
                      i found this website
                      https://www.twowaymirrors.com/smart-mirror/
                      • ? Offline
                        A Former User
                        Thank you Hoosierdad
                        I found this site ,but it doesn’t deliverry to Romania…:)
                        • 2 / 5
