MMM-WunderGround clock and MPH issues
Greetings…
This is my first Raspberry Pi (and therefore, first Magic Mirror) project. I’ve got the MMM-WunderGround module up and running. The PWS i’m using for Knoxville, TN is KTNKNOXV198, and most of the display data seems accurate.
However, at this moment, it’s 12:30 PM EST on March 9, 2018. The default clock module shows this correctly. But, on the WU module, the time is showing as 6:37 (not sure if AM or PM).
Additionally, the wind display is showing as -9999 mph.
Any guidance is appreciated. Thanks!
Edit: config is below. Also noticed that time is not just off, but also ‘stuck’ at 6:37.
{ module: 'MMM-WunderGround', position: 'top_right', config: { apikey: '3027846ee9396ac3', pws: 'pws:KTNKNOXV198', //Knoxville, TN hourly: '1', units: 'imperial', fctext: '1', windunits: 'mph', iconset: 'flat_black', fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0} },
Often times, the sunrise and sunset time is mistaken for a clock. Is 6:37 changing? I suspect this might be your case. The wind issue is likely a problem with the weather station you’ve chosen. To test this, simply choose another PWS close to you and reload. Keep in mind that a PWS is run by average people that just enjoy setting up a station and registering it with Wunderground. They are not maintained by Wunderground. Some are neglected and some don’t offer the same data as others (e.g wind, direction, humidity, etc)
I feel silly for not thinking of those things before I posted. You were correct on both fronts. Thanks again.
No worries my friend. We’ve all been there.
