    CSS 101 - Getting started with CSS and understanding how CSS works
    15 Posts 11 Posters 33.6k Views 19 Watching
      sdetweil @videogame95
      @videogame95 only ever change custom.css
      never change any file we ship or any module ships, as it will break update for any of those
      so, in a css entry the stuff before the { is called the css selector clause, as it ‘selects’ the elements the info between the {} will apply to
      in MagicMirror each module has a container element that uses is name in the class= attribute, so you can select stuff in the calendar module by using its classname
      .calendar
      I use this to help me remember all the stuff that can go in a selector clause
      https://www.w3schools.com/cssref/css_selectors.php
      you can use the developers window, elements tab to see and test changes on any element in the active browser window
      see here for using the developer window
      https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1683502518638
      V C 2 Replies Last reply Reply Quote 0
      • V Offline
        videogame95 @sdetweil
        @sdetweil Hi I’ve add to the custom css
        .MMM-Googlecalendar ,
        But nothing is changing I just need to add
        A border around my text .
        border around the text
        border-color:#000, = block
        Border-size-width : 20px
        Borde-size-hight: 20px
          @videogame95 css is case sensitive like everything else
          be careful on the selector clause, just module name applies to everything
          • C Offline
            Chazzer @sdetweil
            @sdetweil Thanks for the initial tips here.
            • C Offline
              Chazzer
              Great infos and good tips. Thank you 🙏
              • R roth_nj referenced this topic on
              • S svenpisa referenced this topic on
              • kayakbabeK kayakbabe referenced this topic on
              • G greedyvegan referenced this topic on
