    [MMM-NowPlayingOnSpotify] – Display the currently on Spotify playing song
    76 Posts 50 Posters 91.5k Views 51 Watching
    • Y Offline
      yep_DD
      @raywo Your module is amazing. I am using raspotify on my mirror, which is account independent and I was just wondering if there is a chance of implementing spotify connect meta data (e.g. from using raspotify). Instead of using your account as input for the track info using the output from
      systemctl raspotify status
      as the track id. And then use spotifys web api to get the song info?
      https://developer.spotify.com/console/get-track/?id=1yVhDVRJt9o8DQDU3J6R4X&market=
      like this?
      • ? Offline
        A Former User
        It sounds like MMM-SpotifyConnectUI may be better suited for you. I haven’t tried it but it sounds like its exactly what your looking for… and exactly what I’m looking for.
        I have been using MMM-Now PlayingOnSpotify for a while and its really great, however in my house we have a family account, so the module only displays whats playing from my account, not my wife’s, or our guests. My MM is a mirrorless display that is out at our pool, so it’s rare that I’m the only person controlling the music and by rare I mean almost never…lol).
        • ? Offline
          A Former User @murrayireland
          @murrayireland
          This is exactly what the MMM-SpotifyConnectUI does. you need a premium account though.
          • Y Offline
            yep_DD @Guest
            @sharpy400 thanks, I will try immediately. I honestly tried finding a module like that, but that must one I must have overseen.
            edit: nope, won’t work, seems spotify has changed the way they give out API keys none of the instructions will work. Spotify Connect Web seems to rely on libspotify which is obsolete.
            • ? Offline
              A Former User
              Ahhhh Crud. I had high hopes. Sorry about that Thx for checking it out, you saved me some headache
              • N Offline
                nobita @raywo
                @raywo ,How can play and hearing song from Magic Mirror directly (not only display spotify playing song)
                • Y Offline
                  yep_DD @nobita
                  @nobita just install raspotify https://github.com/dtcooper/raspotify
                  the easy way (but I recommend reading the docs):
                  curl -sL https://dtcooper.github.io/raspotify/install.sh | sh
                  • Z Offline
                    Zoran82
                    Hi, would love to try this module but I keep failing installing it.
                    First of all I have quite many messages after npm install. Newbie as I am I tried npm audit fix to fix vulnerabilities. Still had a few (not high) vulnerabilities.
                    What happens is the nothing of this module comes up.
                    Tried again by deleting the module folder and installing again.
                    Druing npm install:
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    added 664 packages from 770 contributors and audited 4892 packages in 233.343s
                    found 16 vulnerabilities (2 low, 7 moderate, 7 high)
                    run npm audit fix to fix them, or npm audit for details
                    pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ npm WARN deprecat ed socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
                    I was playing with another module MMM-RTSPStream and I had to switch to wip develop branch. Is this my problem now?
                    Z 1 Reply Last reply Reply Quote 0
                    • Z Offline
                      Zoran82 @Zoran82
                      @Zoran82 said in [MMM-NowPlayingOnSpotify] – Display the currently on Spotify playing song:
                      Druing npm install:
                      I made it work.
                      I tried again and did a npm audit fix --force this time (without knowing what I actually do).
                      I may have pressed ctrl + z first time, this time i pressed crtl + c (which means I didnt stop service. I think?).
                      Now it’s working as it should.
                      • MondfischM Offline
                        Mondfisch
                        Works 100%!
                        Great Work! Thanx for that!
                          DBTCRon
                          This post is deleted!
                            motdog
                            I just upgraded Spotify to a family account, how can I make it only recognize my music. We each have a unique log in but the module is based on account number. Is there a way to specify which log in?
                            • T Offline
                              tidus5
                              Indeed - having the same issue.
                              i connected my spotify account to google home. And when you ask google home to play some music. it’s considered like an another account.
                                juantata @raywo
                                @raywo Hi. When I call localhost: 888 I get an error
                                • N Offline
                                  namnlp
                                  Hi @raywo , thanks for your Module.
                                  Can you give me any help.
                                  I installed the Module successful, my MM display the status of the song playing on my phone, but i can’t hear the sound from 3.5mm jack or from HDMI of the pi.
                                  I found that Spotify only allow 1 device play at the same time.
                                  Whether i need to upgrade to Premium account?
                                  Thank you.
                                  • T Offline
                                    teitlebot
                                    @Module-Developers is there an module that can show me whats playing on all my google home mini devices from all music carriers not just spotify.
                                      basquille
                                      Anyway to get 2 accounts running on it? The Callback URL is the same so that might be what’s stopping it working I’d say - but anyone get around it.
                                      • Alex2020A Offline
                                        Alex2020
                                        Si può cambiare il colore del logo SPOTIFY quando è disconesso perchè rimane di un grigio troppo chiaro e non si vede il logo se ho uno sfondo con un afoto esempio,ed in caso qual è il comando sul css custom che devo fare?Grazie.
                                        • W Offline
                                          WilliamSkinner
                                          Thanks You!
                                          • H Offline
                                            headbug @namnlp
                                            @namnlp that is not possible, it is not the purpose of this module. It is only showing which song you play on spotify. If you want sound to your Pi you need to install a Spotify client (does not exist for ARM architecture, I think) or surf to the webplayer page: https://open.spotify.com/ but it still won’t play several devices at the same time, regardless of Premium or not.
                                            • 3 / 4
