    [MMM-NowPlayingOnSpotify] – Display the currently on Spotify playing song
    76 Posts 50 Posters 94.7k Views 51 Watching
    • Z
      Zoran82 @Zoran82
      @Zoran82 said in [MMM-NowPlayingOnSpotify] – Display the currently on Spotify playing song:
      Hi, would love to try this module but I keep failing installing it.
      First of all I have quite many messages after npm install. Newbie as I am I tried npm audit fix to fix vulnerabilities. Still had a few (not high) vulnerabilities.
      What happens is the nothing of this module comes up.
      Tried again by deleting the module folder and installing again.
      Druing npm install:
      npm notice created a lockfile as package-lock.json. You should commit this file.
      added 664 packages from 770 contributors and audited 4892 packages in 233.343s
      found 16 vulnerabilities (2 low, 7 moderate, 7 high)
      run npm audit fix to fix them, or npm audit for details
      pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ npm WARN deprecat ed socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
      I was playing with another module MMM-RTSPStream and I had to switch to wip develop branch. Is this my problem now?
      I made it work.
      I tried again and did a npm audit fix --force this time (without knowing what I actually do).
      I may have pressed ctrl + z first time, this time i pressed crtl + c (which means I didnt stop service. I think?).
      Now it’s working as it should.
      • MondfischM
        Mondfisch
        Works 100%!
        Great Work! Thanx for that!
          DBTCRon
            motdog
            I just upgraded Spotify to a family account, how can I make it only recognize my music. We each have a unique log in but the module is based on account number. Is there a way to specify which log in?
            • tidus5T
              tidus5
              Indeed - having the same issue.
              i connected my spotify account to google home. And when you ask google home to play some music. it’s considered like an another account.
                juantata @raywo
                @raywo Hi. When I call localhost: 888 I get an error
                • N
                  namnlp
                  Hi @raywo , thanks for your Module.
                  Can you give me any help.
                  I installed the Module successful, my MM display the status of the song playing on my phone, but i can’t hear the sound from 3.5mm jack or from HDMI of the pi.
                  I found that Spotify only allow 1 device play at the same time.
                  Whether i need to upgrade to Premium account?
                  Thank you.
                  H 1 Reply Last reply
                  • T
                    teitlebot
                    @Module-Developers is there an module that can show me whats playing on all my google home mini devices from all music carriers not just spotify.
                      basquille
                      Anyway to get 2 accounts running on it? The Callback URL is the same so that might be what’s stopping it working I’d say - but anyone get around it.
                      • Alex2020A
                        Alex2020
                        Si può cambiare il colore del logo SPOTIFY quando è disconesso perchè rimane di un grigio troppo chiaro e non si vede il logo se ho uno sfondo con un afoto esempio,ed in caso qual è il comando sul css custom che devo fare?Grazie.
                        • W
                          WilliamSkinner
                          Thanks You!
                          • H
                            headbug @namnlp
                            @namnlp that is not possible, it is not the purpose of this module. It is only showing which song you play on spotify. If you want sound to your Pi you need to install a Spotify client (does not exist for ARM architecture, I think) or surf to the webplayer page: https://open.spotify.com/ but it still won’t play several devices at the same time, regardless of Premium or not.
                              coffeeclimber
                              @raywo, I love this module. It’s clean and simple. Great work. My MagicMirror is not a mirror but rather a central family information center in our main living area. Just like @yep_DD posted earlier last year, we use raspotify. We have no need to control playback via the MagicMirror but it would be great to be able to have multiple account support in some manner, ideally with the ability to only display what is playing on the raspotify device. I listen to Spotify on a lot of different devices and while there is nothing secret about what I listen to, I also can’t see a need for everyone at home to see what I am listening to when I am at work.
                              Since people may have many different Spotify streaming devices, rather than trying to integrate with them directly, what about the ability to apply a filter device names so that the module ONLY displays when you are playing on a certain device(s)? In my case, I could simply duplicate the module, one with my credentials and one with my wife’s credentials. If I could filter each instance to only display a specific device, then in theory it would only display 1 instance of the module at a time. If we had more than 1 device, say the MagicMirror upstairs and another device in the basement, it might be nice to actually see a display of what each of us are playing in the house.
                                castletonroad
                                This module is great!
                                Our MM sits on our office desk as a family info system. We listen to Spotify playlists so this module is great for showing which track is playing - in fact, one family member outright complained after I rebuilt the MM and forgot to include this module again!
                                I see that this module makes DNS requests every second - I’m watching the tail of my pi-hole log. Is there any way to reduce the number of network requests, particularly when the module is idle?
                                • N
                                  Nero
                                  Is there anyway to change the colour of the Spotify logo that sits in the background? I looked in CSS and tried changing the image to a colour one but still no joy. Thanks
                                    sdetweil @headbug
                                    @headbug librespot or raspotify are programs u can install on the pi, outside mm to be able to PLAY Spotify on this device.
                                    the MMM-Spotify module from bugsounet does this for you.
                                    • G
                                      Genosphere
                                      Installed and worked after I rebooted and came back to it the next day. :man_shrugging:
                                      Works quite well aside from after a handful of songs it sort of stalls/freezes on an arbitrary song and if i let it sit for a while or play something outside my network it doesn’t load anything unless I force a reboot of the MM interface(NOT the whole pi).
                                      Anyone else experience the same above and have a fix? (looked through posts and did not see anything)
                                      • K
                                        Karen Clark
                                        • F
                                          fillilutten
                                          I really like it. Would really love to be able to hide all other info beside album art, like progress bar, artist, user, artist, album etc. So I could tune it to be just as I want.
                                          Thanks!
                                          F 1 Reply Last reply
                                          • F
                                            fillilutten @fillilutten
                                            @fillilutten Addition! I would also be able to hide the Spotify logo when just in idle.
                                            • 3 / 4
