MagicMirror² v2.14.0 is available! For more information about this release, check out this topic.
MMM-Assistant google-auth.js
can someone help me with this?
pi@raspberrypi:~/MagicMirror/modules/MMM-Assistant $ node google-auth.js internal/modules/cjs/loader.js:550 throw err; ^ Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/google-auth.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15) at Function.Module._load (internal/modules/cjs/loader.js:475:25) at Function.Module.runMain (internal/modules/cjs/loader.js:695:10) at startup (internal/bootstrap/node.js:201:19) at bootstrapNodeJSCore (internal/bootstrap/node.js:516:3)
i can’t get past this step
@albertlwj the file is in a different directory
do
cd scripts
first
hello thanks for the heads up…i did but now it gives me another error
node google-auth.js /home/pi/MagicMirror/modules/MMM-Assistant/scripts/google-auth.js:27 const assistant = new GoogleAssistant(config) ^^^^^ SyntaxError: Unexpected token const at new Script (vm.js:51:7) at createScript (vm.js:136:10) at Object.runInThisContext (vm.js:197:10) at Module._compile (internal/modules/cjs/loader.js:618:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32) at tryModuleLoad (internal/modules/cjs/loader.js:506:12) at Function.Module._load (internal/modules/cjs/loader.js:498:3) at Function.Module.runMain (internal/modules/cjs/loader.js:695:10) at startup (internal/bootstrap/node.js:201:19)
I don’t think you have installed the module according to the README.
It seem that you never didnpm install
But there are some other trouble with that script, that I am trying to fix as we speak…
script is fixed! Get the latest script and See comment in the issue you started.
@e3v3a I’m having a similar issue after running
node google-auth.js
I get the following… what am I missing? It looks like it can’t locate google -client-secret.json but I don’t see a step anywhere where that should have been created.
node google-auth.js internal/modules/cjs/loader.js:550 throw err; ^ Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/assets/google-client-secret.json' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15) at Function.Module._load (internal/modules/cjs/loader.js:475:25) at Module.require (internal/modules/cjs/loader.js:598:17) at require (internal/modules/cjs/helpers.js:11:18) at new Auth (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/components/auth.js:26:15) at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/index.js:21:16) at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/scripts/google-auth.js:25:19) at Module._compile (internal/modules/cjs/loader.js:654:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32)
