    MMM-Cocktails - Images now showing up?
    7 Posts 3 Posters 2.6k Views 2 Watching
    • H
      HYKGOML
      Re: MMM-Cocktails
      Installed and got the feeds (text) woriking. What does not work is the images.
      Using Shift-Alt-I I see the module is looking for an image file that is not there.
      Example:
      Broken (as not displayed in the Mirror)
      http://https//www.thecocktaildb.com/images/media/drink/0fbo2t1485620752.jpg
      So it seems to be getting redirected to the https site, but has already padded the URL with HTTP…
      Correct URL:
      https://www.thecocktaildb.com/images/media/drink/0fbo2t1485620752.jpg
      The website seems to have updated their API to support HTTPS :
      https://www.thecocktaildb.com/api.php
      IDK, I assume because of google? ( https://www.theverge.com/2018/2/8/16991254/chrome-not-secure-marked-http-encryption-ssl )
      So I think I get the issue, I just don’t know how to fix…
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @HYKGOML
        @hykgoml
        I will take a look at this tonight. Sorry for the delay. Work and grandchildren keeping me busy.
        • H
          HYKGOML
          No apologies needed at ALL. Those things always are more important.
          … and don’t skin me over the fact I also put in a defect on Git… Was not sure best place to post this.
          I look forward to to the process as I have theories on whats wrong and what the fix might be. But I gave it a go did not have success.
          Now go back to having a life!
          Mykle1M cowboysdudeC 2 Replies Last reply
          Reply Quote 1
          • Mykle1M
            @hykgoml
            Thanks for bringing that to my attention. I don’t always check for issues on the hub. Evidently, the api changed a bit but the fix was simple. See line 65 and 66 of the MMM-Cocktails.js file if you’re curious. I’ve had it running for an hour now without incident.
            I’ll upload the update to the hub. You can do a git pull in the MMM-Cocktails directory for the update. Let me know how you make out.
            EDIT:
            Updated on github
            H 1 Reply Last reply
            Reply Quote 1
            • cowboysdudeC
              cowboysdude Module Developer @HYKGOML
              @hykgoml Generally fixes are simple for the developer so if you have a problem just let them know ;) LOTS easier then trying to figure it out…you may really break something in the process ;)
              • H
                HYKGOML @Mykle1
                @mykle1
                (reads line 65-66)
                Ohhh ok I see what you did… Cool thanks! (not a java programmer) so the syntax is a bit new for me.
                Thanks again!
                TLDR; Yep works great!
                Cheers!
                • Mykle1M
                  @hykgoml
                  Great!
                  Reply Quote 1
