    MMM-Cocktails - Images now showing up?
    7 Posts 3 Posters 2.2k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @HYKGOML
      @hykgoml
      I will take a look at this tonight. Sorry for the delay. Work and grandchildren keeping me busy.
      • H Offline
        HYKGOML
        No apologies needed at ALL. Those things always are more important.
        … and don’t skin me over the fact I also put in a defect on Git… Was not sure best place to post this.
        I look forward to to the process as I have theories on whats wrong and what the fix might be. But I gave it a go did not have success.
        Now go back to having a life!
        Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
          @hykgoml
          Thanks for bringing that to my attention. I don’t always check for issues on the hub. Evidently, the api changed a bit but the fix was simple. See line 65 and 66 of the MMM-Cocktails.js file if you’re curious. I’ve had it running for an hour now without incident.
          I’ll upload the update to the hub. You can do a git pull in the MMM-Cocktails directory for the update. Let me know how you make out.
          EDIT:
          Updated on github
          H 1 Reply Last reply Reply Quote 1
          • cowboysdudeC Offline
            cowboysdude Module Developer @HYKGOML
            @hykgoml Generally fixes are simple for the developer so if you have a problem just let them know ;) LOTS easier then trying to figure it out…you may really break something in the process ;)
            • H Offline
              HYKGOML @Mykle1
              @mykle1
              (reads line 65-66)
              Ohhh ok I see what you did… Cool thanks! (not a java programmer) so the syntax is a bit new for me.
              Thanks again!
              TLDR; Yep works great!
              Cheers!
                @hykgoml
                Great!
