    MMM-Wunderlist not updating
    17 Posts 12 Posters 13.4k Views 11 Watching
    • W Offline
      witschi87
      I have the same issue. I think it depends on the mirror is losing its wlan connection for some time. but I’m not sure… I can’t find anything in the logs.
        Sunburned
        Hey all,
        I had the same issue, there is a good troubleshooting thread here https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/85
        I ended up setting up a cron job to restart the pi and mirror each night at 2am and increased the wunderlist update interval to 120. That was about 2 weeks ago and so far so good.
        • T Offline
          tajno
          May its not enough if you make “pm2 reload <magicmirrorscript.sh>”? By then a reboot is not necessary.
          • E Offline
            Ed
            Ok. I have problem with update lists.
            I use crontab to restart MM 12 times a day after 2hours work
            Pm2 reload not help.
            i don’t see any errors in log.
            The same issue i have with todolist plugin.
            Is any chance to solve this problem?
            • C Offline
              Chiumanfu
              I have the same problem. Any one have a solution other than reboot cron job. Seems like a bandaid.
              • joela85J Offline
                joela85
                Did anyone find any solutions to this? I’m facing the same problem. Have not set up a crontab to restart yet. Was hoping for a different solution.
                • joela85J Offline
                  joela85
                  Guessing everyone gave up with this then?
                  • cruunnerrC Offline
                    cruunnerr
                    Got the same problem.
                    Runs for a few hours and then the module seems to freeze. Doesn’t update anymore.
                    this morning i did a “pm2 flush”
                    This evening i checked the “pm2 logs”
                    0|mm       | there was a Wunderlist problem { error:
                    0|mm       |    { type: 'server_error',
                    0|mm       |      translation_key: 'api_error_unknown',
                    0|mm       |      message: 'An unknown server error occurred' } } 500
                    Maybe someone has an idea…
                    • schwoediauerS Offline
                      schwoediauer
                      Hi community, I have the same problem and no solution is available until now?
                        cruunnerr
                        This is in some way a problem of Wunderlist. :/
                        So nothing u can do as far as i know. I searched long for a solution until i finally disabled the module. :(
                        Maybe u try this: https://forum.magicmirror.builders/topic/566/mmm-todoist-your-todoist-tasks-on-your-mirror
                        i didn’t try it yet
