    MMM-Wunderlist not updating
    17 Posts 12 Posters 15.2k Views 11 Watching
    • E Offline
      Ed
      Ok. I have problem with update lists.
      I use crontab to restart MM 12 times a day after 2hours work
      Pm2 reload not help.
      i don’t see any errors in log.
      The same issue i have with todolist plugin.
      Is any chance to solve this problem?
        Chiumanfu
        I have the same problem. Any one have a solution other than reboot cron job. Seems like a bandaid.
        • joela85J Offline
          joela85
          Did anyone find any solutions to this? I’m facing the same problem. Have not set up a crontab to restart yet. Was hoping for a different solution.
          • joela85J Offline
            joela85
            Guessing everyone gave up with this then?
            • cruunnerrC Offline
              cruunnerr
              Got the same problem.
              Runs for a few hours and then the module seems to freeze. Doesn’t update anymore.
              this morning i did a “pm2 flush”
              This evening i checked the “pm2 logs”
              0|mm       | there was a Wunderlist problem { error:
              0|mm       |    { type: 'server_error',
              0|mm       |      translation_key: 'api_error_unknown',
              0|mm       |      message: 'An unknown server error occurred' } } 500
              Maybe someone has an idea…
              • schwoediauerS Offline
                schwoediauer
                Hi community, I have the same problem and no solution is available until now?
                  cruunnerr
                  This is in some way a problem of Wunderlist. :/
                  So nothing u can do as far as i know. I searched long for a solution until i finally disabled the module. :(
                  Maybe u try this: https://forum.magicmirror.builders/topic/566/mmm-todoist-your-todoist-tasks-on-your-mirror
                  i didn’t try it yet
                    schwoediauer
                    I think wunderlis will merge or migrate to Microsoft To-Do. Maybe we should work on this solution instead of debuging the MMM-Wunderlist module
                      ArneCL
                      The problem is based on the fact that MMM-Wunderlist currently uses the official (but deprecated) wunderlist-module to access the API. Looking around and finding no suitable replacement for Wunderlist, I created a fix for this, which seems to run stable (at least for the last two days). (I also recently created a PR which allows the use of multiple accounts and multiple instance with MMM-Wunderlist …)
                      If you would appreciate a fix, give this post an upvote (As a PR still means work…)
                      @schwoediauer You are right, the situation about wunderlist is quite diffuse. According to them, wunderlist will be discontinued in the long run :crying_face: (talking years?). However, the IOs App has been updated quite recently (30th March 2018), so they still seem to keep it alive (?). For me Microsoft ToDo can not replace the to-the-pointness of wunderlist…
                      1 Reply Last reply Reply Quote 5
                        paviro
                        This diffuse situation is the reason I stopped updating the module. Thanks @ArneCL for still working on it!
                        – The Doctor
