    MMM-Wunderlist not updating
    17 Posts 12 Posters 13.6k Views 11 Watching
    • paviroP Offline
      paviro
      Are there any logs?
      – The Doctor
      • pugslyP Offline
        pugsly
        Not that I have found, only logs I know about are under .pm2/logs
        • G Offline
          gverbist
          I have the same issue. It gets updated for a few hours and then it just stops doing updates.
          The rest of the mirror like calendar and weather works fine. Changing the interval also doesnt seem to work.
          The same issue occurs with the news feed via rss.
          • W Offline
            witschi87
            I have the same issue. I think it depends on the mirror is losing its wlan connection for some time. but I’m not sure… I can’t find anything in the logs.
              Sunburned
              Hey all,
              I had the same issue, there is a good troubleshooting thread here https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/85
              I ended up setting up a cron job to restart the pi and mirror each night at 2am and increased the wunderlist update interval to 120. That was about 2 weeks ago and so far so good.
              • T Offline
                tajno
                May its not enough if you make “pm2 reload <magicmirrorscript.sh>”? By then a reboot is not necessary.
                • E Offline
                  Ed
                  Ok. I have problem with update lists.
                  I use crontab to restart MM 12 times a day after 2hours work
                  Pm2 reload not help.
                  i don’t see any errors in log.
                  The same issue i have with todolist plugin.
                  Is any chance to solve this problem?
                    Chiumanfu
                    I have the same problem. Any one have a solution other than reboot cron job. Seems like a bandaid.
                    • joela85J Offline
                      joela85
                      Did anyone find any solutions to this? I’m facing the same problem. Have not set up a crontab to restart yet. Was hoping for a different solution.
                      • joela85J Offline
                        joela85
                        Guessing everyone gave up with this then?
