    MMM-Wunderlist not updating
    17 Posts 12 Posters 13.3k Views 11 Watching
      Sunburned
      Hey all,
      I had the same issue, there is a good troubleshooting thread here https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/85
      I ended up setting up a cron job to restart the pi and mirror each night at 2am and increased the wunderlist update interval to 120. That was about 2 weeks ago and so far so good.
      • T Offline
        tajno
        May its not enough if you make “pm2 reload <magicmirrorscript.sh>”? By then a reboot is not necessary.
        • E Offline
          Ed
          Ok. I have problem with update lists.
          I use crontab to restart MM 12 times a day after 2hours work
          Pm2 reload not help.
          i don’t see any errors in log.
          The same issue i have with todolist plugin.
          Is any chance to solve this problem?
            Chiumanfu
            I have the same problem. Any one have a solution other than reboot cron job. Seems like a bandaid.
            • joela85J Offline
              joela85
              Did anyone find any solutions to this? I’m facing the same problem. Have not set up a crontab to restart yet. Was hoping for a different solution.
              • joela85J Offline
                joela85
                Guessing everyone gave up with this then?
                • cruunnerrC Offline
                  cruunnerr
                  Got the same problem.
                  Runs for a few hours and then the module seems to freeze. Doesn’t update anymore.
                  this morning i did a “pm2 flush”
                  This evening i checked the “pm2 logs”
                  0|mm       | there was a Wunderlist problem { error:
                  0|mm       |    { type: 'server_error',
                  0|mm       |      translation_key: 'api_error_unknown',
                  0|mm       |      message: 'An unknown server error occurred' } } 500
                  Maybe someone has an idea…
                  • schwoediauerS Offline
                    schwoediauer
                    Hi community, I have the same problem and no solution is available until now?
                      cruunnerr
                      This is in some way a problem of Wunderlist. :/
                      So nothing u can do as far as i know. I searched long for a solution until i finally disabled the module. :(
                      Maybe u try this: https://forum.magicmirror.builders/topic/566/mmm-todoist-your-todoist-tasks-on-your-mirror
                      i didn’t try it yet
                        schwoediauer
                        I think wunderlis will merge or migrate to Microsoft To-Do. Maybe we should work on this solution instead of debuging the MMM-Wunderlist module
