    Black screen after installation on Pi 2 model B V1.1
    13 Posts 4 Posters 9.1k Views 4 Watching
    • V
      vicdilou
      Hello,
      I use the auto install and after duplicate “config.js.sample” to “config.js” but when I launch “index.html” and I have a blackscreen. I did not change the “config.js”.
      Help me please ^^
      strawberry 3.141S 1 Reply Last reply
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @vicdilou
        @vicdilou what do you mean with launch index.html? did you open this file in a browser? or did you started with npm or node server only?
        • V
          vicdilou
          I open the file in a browser. How i have to launch it ?
          • strawberry 3.141S
            @vicdilou cd ~/MagicMirror then npm start
            • V
              vicdilou
              I tried this before but it doesn’t work and now it work !
              Thank you.
              edit : How to close it properly ?
              • P
                PaulB
                @strawberry-3-141 thanks for the great advice.
                Ive tried your advise. Nevertheless my screen is now completely black, too.
                Ive tried it several times now, sometimes it works sometimes it doesn’t.
                After Ive changed the API Key of openwjeathermaps my screen went black again.
                So @strawberry-3-141 do you have and advise maybe? :-)
                Kind Regards from Germany,
                Paul
                B 1 Reply Last reply
                • B
                  bhepler Module Developer @PaulB
                  @PaulB A completely black screen usually means there is an error in the config.js file. Please post yours, (specifically the openweathermaps module entry) using the markdown features and we’ll take a look at it.
                  • P
                    PaulB
                    @bhelper I am trying to :-D
                    /* Magic Mirror Config Sample
                    • By Michael Teeuw http://michaelteeuw.nl
                    • MIT Licensed.
                    var config = {
                    port: 8080,
                    language: 'de',
                    timeFormat: 24,
                    units: 'metric',
                    		module: 'alert',
                    		module: 'clock',
                    		position: 'top_left'
                    		module: 'calendar',
                    		header: 'US Holidays',
                    		position: 'top_left',
                    					symbol: 'calendar-check-o ',
                    					url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                    		module: 'compliments',
                    		position: 'lower_third'
                    		module: 'Aktuelles Wetter',
                    		position: 'top_right',
                    			locationID: '5128581',  //ID from http://www.openweathermap.org
                    			appid: '158010f0c45e255e6439eb1885b3482b'
                    		module: 'Wettervorhersage',
                    		header: 'Wettervorhersage',
                    		module: 'newsfeed',
                    		position: 'bottom_bar',
                    			feeds: [
                    					title: "New York Times",
                    			showSourceTitle: true,
                    			showPublishDate: true
                    if (typeof module !== ‘undefined’) {module.exports = config;}
                    • B
                      At a guess, it looks like you put the header for your module in the module name specification. The module: [name] lines must match the name of the module. These names also correspond with folders in the ~/MagicMirror/modules path. The modules that are installed with the MagicMirror code (which I believe you are trying to use) will be in ~/MagicMirror/modules/default/[module name]
                      So try this instead:
                      		module: 'currentweather',
                      		module: 'weatherforecast',
                      • P
                        PaulB
                        @bhepler You are a Genius! Thanks a lot. :-)
                        Changing the module names was not my best idea, I guess :D
                        P 1 Reply Last reply
                        • P
                          PaulB @PaulB
                          Nevertheless the index.html-file shows me just a black screen.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @PaulB
                            @PaulB the html file itself will show only a black screen, the modules get loaded dinamically so there is no point in open the html file in a browser, if you want to open the mirror onto another computer and type in the ip followed by the port specified in the config.js
                            • P
                              PaulB
                              @strawberry-3-141 Ah!Now I get it. Thank you very much for your help. :-)
