    Can you help me about this error
    29 Posts 4 Posters 10.1k Views 4 Watching
    • F Offline
      Fonfon
      I don’t know why ?
      is it a module ?
      witch one ?
      thanks
        Mykle1 Project Sponsor Module Developer @Fonfon
        @fonfon
        Are you getting this error with the default modules only? Disable all other modules and see. Then add one at a time to see which generates the error.
        • F Offline
          Fonfon
          Hi Mykle1,
          Indeed by elimination I think I can find the module that generates this error
          i try this thanks .
          and after if is it a module ?
          justjim1220J 1 Reply Last reply Reply Quote 0
          • justjim1220J Offline
            justjim1220 Module Developer @Fonfon
            @fonfon
            I had that error a few times, it was always an error in the config.js file. use a Js Linter to help you find the errors.
            Jim Hallock - 1995
            • F Offline
              Fonfon @justjim1220
              @justjim1220 thanks i use jshint.com no error
              justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                @fonfon
                next thing to try it to npm install in each individual module directory
                then npm rebuild in the MagicMagic directory
                let me know if that helps!
                Jim Hallock - 1995
                  @fonfon
                  Did you determine which module is causing the error?
                  • F Offline
                    Fonfon @Mykle1
                    @mykle1 Thanks mykle1 but no !
                    for desactivate a module i cut/paste the folder on the desktop then i restart the MM is it the good method ?
                    because when i have no module its ok no error
                    only with pir module its good
                    but after with wunderground or google maps traffic module i have a lot of error or other…
                    i don’t understand !!
                    this after the update in 2.4.1.
                    Mykle1M justjim1220J 5 Replies Last reply Reply Quote 0
                      @fonfon said in Can you help me about this error:
                      This is how I disable modules without copying and pasting and moving things around. You can simply add disabled: false, at the beginning of all your config.js entries. true will disable the module.
                                  disabled: false,
                                  module: 'MMM-EventHorizon',
                                  position: 'bottom_left',
                                      date: "2018-09-17", // (YYYY-MM-DD)  Date timer will end
                                      time: "00:01:00", // (HH:MM:SS)    Exact time you want timer to end
                                      text1: "Lucy's Birthday", // 2 lines of text during timer
                                      text2: "Tempus Fugit", // 2 lines of text during timer
                                      endText1: "Lucy is 1 today!", // 2 lines of text when timer ends
                                      endText2: "What a big girl!", // 2 lines of text when timer ends
                      justjim1220J 1 Reply Last reply Reply Quote 1
                        @fonfon
                        no need to cut/paste each module…
                        you can add
                           disabled: false
                        above each module, like this…
                            disabled: false,
                            module: "clock",
                            position: "top_center"
                        then, you can change it to true to shut off the module.
                        it would be the easiest way to determine which module is causing the issue.
                        load all your modules back into the config.js,
                        add the code above,
                        make all the default modules ‘false’,
                        and all the rest ‘true’,
                        refresh your mirror,
                        if you still get the same issues,
                        turn off the mirror and your terminal,
                        maybe even restart your computer,
                        then open your terminal,
                        restart the mirror with ‘npm start -dev’
                        this will give you an error log, find that and post it in here,
                        this would be easier for us to help you
                        Jim Hallock - 1995
                        • 1 / 3
