    Can you help me about this error
    29 Posts 4 Posters 11.0k Views 4 Watching
    • F Offline
      Fonfon @Mykle1
      @mykle1 yes with default modules
        Mykle1 Project Sponsor Module Developer @Fonfon
        @fonfon said in Can you help me about this error:
        only with pir module its good
        but after with wunderground or google maps traffic module i have a lot of error or other…
        Above you said with pir module its good . . . .
        So now I am confused. I think that perhaps we don’t understand each other. Run MM with ONLY the default modules. If you are having trouble that way then your problem lies with your installation of MM.
        • ? Offline
          A Former User @Fonfon
          @fonfon
          I think there is invalid ’timezone’ value in your config(whichever it is)
          Have you set any value with ’Etc/gmt+1’?
          • F Offline
            Fonfon @Guest
            @sean yes in my config for clock module i have gmt +1
            ? 2 Replies Last reply Reply Quote 0
            • ? Offline
              @fonfon
              Use Etc/GMT+1 instead Etc/GMT+01.
              But, this modifying only can fix your front-end error of Moment Timezone has no data for..., not your UnhandledPromise... error in the background-server.
              You should remove modules one-by-one to figure out which module is causing that error.
              • ? Offline
                @fonfon
                And Could you tell us which modules are in your config.js?
                • F Offline
                  Fonfon
                  OK guys i think i find my problems:
                  You have included the Google Maps JavaScript API multiple times on this page.This may cause unexpected errors
                  The google trafic module is the cause
                  An idea to fix it ?
                  thanks
                  • ? Offline
                    @fonfon
                    First, I think you’d better ask the creator on Github.
                    Second, Have you registered that module once?
                    • F Offline
                      Fonfon
                      ok when i started only MMM-GoogleMapsTraffic in dev mode:
                      Dev say i start with 5 keys but in my config file i have only one !
                      thanks
