    Can you help me about this error
    29 Posts 4 Posters 11.5k Views 4 Watching
    • F
      Fonfon @Mykle1
      This is after only 15 min of MM running
      ? 2 Replies Last reply
        A Former User @Fonfon
        @fonfon
        One of your modules is using promise pattern but not handling rejection. Usually this is caused by missing some exception handling in module.
        I cannot figure out which module is causing that message. You can find which module has problem by disabling or removing module from config.js one-by-one.
        Maybe your suspicious module might have SOMETHING.hash in its codes. the error will be caused object SOMETHING is really null. so, when you find which module has the error, tell the module developer the symptom. (S)he will fix it.
          @fonfon
          And one more thing.
          Most of those UnhandledPromiseRejectionWarning does not give harm to MM’s execution, the real problem is TypeError: Cannot read property 'hash' of null. You should find which module is causing this message.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Fonfon
            @fonfon said in Can you help me about this error:
            i try to start with npm start -dev for a error log
            where is the error log in wich folder?
            Start MM with npm start dev. This opens the Developers Tools window. Click “Console” tab at the top of the window. Here you will find any errors. It does not save as a log.
            Follow Sean’s suggestion (and mine) that you determine which module is causing the issue. Then paste the errors from that module here.
            F 1 Reply Last reply
            • F
              Fonfon @Mykle1
              @mykle1 When i start with npm start dev: 0_1533511909992_2018-08-06-012648_1080x1920_scrot.jpg
              Mykle1M ? 2 Replies Last reply
              • Mykle1M
                @fonfon
                Do you get that error with just the default modules?
                • F
                  Fonfon @Mykle1
                  @mykle1 yes with default modules
                  • Mykle1M
                    only with pir module its good
                    but after with wunderground or google maps traffic module i have a lot of error or other…
                    Above you said with pir module its good . . . .
                    So now I am confused. I think that perhaps we don’t understand each other. Run MM with ONLY the default modules. If you are having trouble that way then your problem lies with your installation of MM.
                      @fonfon
                      I think there is invalid ’timezone’ value in your config(whichever it is)
                      Have you set any value with ’Etc/gmt+1’?
                      • F
                        Fonfon @Guest
                        @sean yes in my config for clock module i have gmt +1
                          @fonfon
                          Use Etc/GMT+1 instead Etc/GMT+01.
                          But, this modifying only can fix your front-end error of Moment Timezone has no data for..., not your UnhandledPromise... error in the background-server.
                          You should remove modules one-by-one to figure out which module is causing that error.
                            @fonfon
                            And Could you tell us which modules are in your config.js?
                            • F
                              Fonfon
                              OK guys i think i find my problems:
                              You have included the Google Maps JavaScript API multiple times on this page.This may cause unexpected errors
                              The google trafic module is the cause
                              An idea to fix it ?
                              thanks
                              ? 1 Reply Last reply
                                @fonfon
                                First, I think you’d better ask the creator on Github.
                                Second, Have you registered that module once?
                                • F
                                  Fonfon
                                  ok when i started only MMM-GoogleMapsTraffic in dev mode:
                                  Dev say i start with 5 keys but in my config file i have only one !
                                  thanks
