    Can you help me about this error
    29 Posts 4 Posters 11.5k Views 4 Watching
      A Former User @Fonfon
      @fonfon
      And one more thing.
      Most of those UnhandledPromiseRejectionWarning does not give harm to MM’s execution, the real problem is TypeError: Cannot read property 'hash' of null. You should find which module is causing this message.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Fonfon
        @fonfon said in Can you help me about this error:
        i try to start with npm start -dev for a error log
        where is the error log in wich folder?
        Start MM with npm start dev. This opens the Developers Tools window. Click “Console” tab at the top of the window. Here you will find any errors. It does not save as a log.
        Follow Sean’s suggestion (and mine) that you determine which module is causing the issue. Then paste the errors from that module here.
        F 1 Reply Last reply
        • F
          Fonfon @Mykle1
          @mykle1 When i start with npm start dev: 0_1533511909992_2018-08-06-012648_1080x1920_scrot.jpg
          Mykle1M ? 2 Replies Last reply
          • Mykle1M
            @fonfon
            Do you get that error with just the default modules?
            • F
              Fonfon @Mykle1
              @mykle1 yes with default modules
              • Mykle1M
                only with pir module its good
                but after with wunderground or google maps traffic module i have a lot of error or other…
                Above you said with pir module its good . . . .
                So now I am confused. I think that perhaps we don’t understand each other. Run MM with ONLY the default modules. If you are having trouble that way then your problem lies with your installation of MM.
                  @fonfon
                  I think there is invalid ’timezone’ value in your config(whichever it is)
                  Have you set any value with ’Etc/gmt+1’?
                  • F
                    Fonfon @Guest
                    @sean yes in my config for clock module i have gmt +1
                      @fonfon
                      Use Etc/GMT+1 instead Etc/GMT+01.
                      But, this modifying only can fix your front-end error of Moment Timezone has no data for..., not your UnhandledPromise... error in the background-server.
                      You should remove modules one-by-one to figure out which module is causing that error.
                        @fonfon
                        And Could you tell us which modules are in your config.js?
                        • F
                          Fonfon
                          OK guys i think i find my problems:
                          You have included the Google Maps JavaScript API multiple times on this page.This may cause unexpected errors
                          The google trafic module is the cause
                          An idea to fix it ?
                          thanks
                          ? 1 Reply Last reply
                            @fonfon
                            First, I think you’d better ask the creator on Github.
                            Second, Have you registered that module once?
                            • F
                              Fonfon
                              ok when i started only MMM-GoogleMapsTraffic in dev mode:
                              Dev say i start with 5 keys but in my config file i have only one !
                              thanks
