    Can you help me about this error
    29 Posts 4 Posters 10.6k Views 4 Watching
    • F Offline
      Fonfon
      I don’t know why ?
      is it a module ?
      witch one ?
      thanks
        Mykle1 Project Sponsor Module Developer @Fonfon
        @fonfon
        Are you getting this error with the default modules only? Disable all other modules and see. Then add one at a time to see which generates the error.
        • F Offline
          Fonfon
          Hi Mykle1,
          Indeed by elimination I think I can find the module that generates this error
          i try this thanks .
          and after if is it a module ?
          • justjim1220J Offline
            justjim1220 Module Developer @Fonfon
            @fonfon
            I had that error a few times, it was always an error in the config.js file. use a Js Linter to help you find the errors.
            "Life's Too Short To Dance With Ugly People"
            Jim Hallock - 1995
            • F Offline
              Fonfon @justjim1220
              @justjim1220 thanks i use jshint.com no error
              justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                @fonfon
                next thing to try it to npm install in each individual module directory
                then npm rebuild in the MagicMagic directory
                let me know if that helps!
                Jim Hallock - 1995
                  @fonfon
                  Did you determine which module is causing the error?
                  • F Offline
                    Fonfon @Mykle1
                    @mykle1 Thanks mykle1 but no !
                    for desactivate a module i cut/paste the folder on the desktop then i restart the MM is it the good method ?
                    because when i have no module its ok no error
                    only with pir module its good
                    but after with wunderground or google maps traffic module i have a lot of error or other…
                    i don’t understand !!
                    this after the update in 2.4.1.
                    Mykle1M justjim1220J 5 Replies Last reply Reply Quote 0
                      @fonfon said in Can you help me about this error:
                      This is how I disable modules without copying and pasting and moving things around. You can simply add disabled: false, at the beginning of all your config.js entries. true will disable the module.
                                  disabled: false,
                                  module: 'MMM-EventHorizon',
                                  position: 'bottom_left',
                                      date: "2018-09-17", // (YYYY-MM-DD)  Date timer will end
                                      time: "00:01:00", // (HH:MM:SS)    Exact time you want timer to end
                                      text1: "Lucy's Birthday", // 2 lines of text during timer
                                      text2: "Tempus Fugit", // 2 lines of text during timer
                                      endText1: "Lucy is 1 today!", // 2 lines of text when timer ends
                                      endText2: "What a big girl!", // 2 lines of text when timer ends
                      justjim1220J 1 Reply Last reply Reply Quote 1
                        @fonfon
                        no need to cut/paste each module…
                        you can add
                           disabled: false
                        above each module, like this…
                            disabled: false,
                            module: "clock",
                            position: "top_center"
                        then, you can change it to true to shut off the module.
                        it would be the easiest way to determine which module is causing the issue.
                        load all your modules back into the config.js,
                        add the code above,
                        make all the default modules ‘false’,
                        and all the rest ‘true’,
                        refresh your mirror,
                        if you still get the same issues,
                        turn off the mirror and your terminal,
                        maybe even restart your computer,
                        then open your terminal,
                        restart the mirror with ‘npm start -dev’
                        this will give you an error log, find that and post it in here,
                        this would be easier for us to help you
                        Jim Hallock - 1995
                          justjim1220 Module Developer @Mykle1
                          @mykle1
                          LMAO!
                          I was posting my reply when yours popped up! :winking_face:
                          Jim Hallock - 1995
                            @fonfon
                            Jim Hallock - 1995
                              @fonfon
                              I’d like to see any errors from your terminal and/or your console
                              • F Offline
                                Fonfon @justjim1220
                                @justjim1220
                                info it worked if it ends with ok
                                1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                                2 info using npm@3.10.10
                                3 info using node@v6.13.1
                                4 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                                4 verbose stack at Error (native)
                                5 verbose cwd /home/pi/MagicMirror/modules
                                6 error Linux 4.9.59-v7+
                                7 error argv “/usr/bin/node” “/usr/bin/npm” “start”
                                8 error node v6.13.1
                                9 error npm v3.10.10
                                10 error path /home/pi/MagicMirror/modules/package.json
                                11 error code ENOENT
                                12 error errno -2
                                13 error syscall open
                                14 error enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                                15 error enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                                15 error enoent This is most likely not a problem with npm itself
                                15 error enoent and is related to npm not being able to find a file.
                                16 verbose exit [ -2, true ]
                                this is my npm-debug.log
                                i dont understand it i think its a problem with package .js
                                i try to start with npm start -dev for a error log
                                where is the error log in wich folder?
                                thanks for your help
                                • F Offline
                                  Fonfon @Mykle1
                                  This is after only 15 min of MM running
                                    A Former User @Fonfon
                                    @fonfon
                                    One of your modules is using promise pattern but not handling rejection. Usually this is caused by missing some exception handling in module.
                                    I cannot figure out which module is causing that message. You can find which module has problem by disabling or removing module from config.js one-by-one.
                                    Maybe your suspicious module might have SOMETHING.hash in its codes. the error will be caused object SOMETHING is really null. so, when you find which module has the error, tell the module developer the symptom. (S)he will fix it.
                                      @fonfon
                                      And one more thing.
                                      Most of those UnhandledPromiseRejectionWarning does not give harm to MM’s execution, the real problem is TypeError: Cannot read property 'hash' of null. You should find which module is causing this message.
                                        Start MM with npm start dev. This opens the Developers Tools window. Click “Console” tab at the top of the window. Here you will find any errors. It does not save as a log.
                                        Follow Sean’s suggestion (and mine) that you determine which module is causing the issue. Then paste the errors from that module here.
                                        • F Offline
                                          Fonfon @Mykle1
                                          @mykle1 When i start with npm start dev: 0_1533511909992_2018-08-06-012648_1080x1920_scrot.jpg
                                          Mykle1M ? 2 Replies Last reply Reply Quote 0
                                            @fonfon
                                            Do you get that error with just the default modules?
