MMA - Praytime
Hello ,
I have a Problem with the config file Can someone Help me
Thats my config file
this is my config file
/*************** DO NOT EDIT THE LINE BELOW **************/
if (typeof module !== “undefined”) {module.exports = config;}
/ Magic Mirror Config Sample
*By Michael Teeuw http://michaelteeuw.nl
MIT Licensed.
For more information how you can configurate this file
See https://github.com/MichMich/MagicMirror#configuration
*/var config = {
address: “localhost”, // Address to listen on, can be:
// - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: “de”,
timeFormat: 24,
units: “metric”,modules: [
module: ‘MMM-PrayerTime’,
position: ‘bottom_right’, .
apiVersion: ‘1.0’,
lat: 31.972836,
lon: 35.898916,
timezone: ‘Asia/Dubai’, // please refer to http://php.net/manual/en/timezones.asia.php
timeFormat: 12,
method: 5,
playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
notDisplayed: [‘midnight’, ‘sunset’],
useUpdateInterval: true,
updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
language: config.language | ‘en’,
showAdzanAlert: true,
alertTimer: 15000
module: “alert”,
},{ module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Ferien NRW", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } },
there where a few syntax errors,
But the biggest issues I am finding is your quotes and double quotes…
this is what is showing for in the cofig I copied from your config…
‘bottom_right’
“alert”this is what it should look like…
‘bottom_right’
“alert”you can see there is a difference by the slant of the quotes…
Hope this helps!
Made a few modifications…
Will leave the quotes to you to fix!/* Magic Mirror config.js * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"] language: “de”, timeFormat: 24, units: “metric”, modules: [ { module: ‘MMM-PrayerTime’, position: ‘bottom_right’, . config: { apiVersion: ‘1.0’, lat: 31.972836, lon: 35.898916, timezone: ‘Asia/Dubai’, // please refer to http://php.net/manual/en/timezones.asia.php timeFormat: 12, method: 5, playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’], notDisplayed: [‘midnight’, ‘sunset’], useUpdateInterval: true, updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds) animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds) language: config.language | ‘en’, showAdzanAlert: true, alertTimer: 15000 } }, { module: “alert” }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Ferien NRW", position: "top_left", config: { calendars: [ symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW **************/ if (typeof module !== “undefined”) {module.exports = config;}
@govabm - Take @justjim1220 example of a fixed
config.js
and remove the"
from in front of thelat:
value. The values being passed are real numbers and not strings. So they do not need quotes around them.Additionally, you specify both German and English as your language. You should probably pick one and stick with it.
Thanks for the catch!
didn’t even noticed That I had put that there!!!
@justjim1220 - It just sort of jumped out at me. Of course, now that I think about it, it’s entirely possible that the module needs quotes around those values. I don’t think so, based upon my quick glance at the source code. But I could be wrong. And I don’t have the time to install that module and try it out.
But hey, @govabm can try it without quotes and then with quotes and let us know what works. The module readme really should provide a working example other than just listing the default of
false
My issue with it is not knowing why I would put just the first quotes and not finish it with quotes…
@justjim1220 i installed complete Sm mirror again now its work i config now the moduls on the screen do you know all the position on the screen witch i can select ?
ou no i have some mistakes
i edit the possition on the screen know its show me i shoud config the file
thats a working file know
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "de", timeFormat: 24, units: "metric", modules: [ { module:'MMM-PrayerTime', position: 'bottom_left', config: { apiVersion: "1.0", lat: 55.841727, lon: 13.303381, timezone: 'Europe/Berlin', timeFormat: 24, method: 2, playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'], notDisplayed: ['midnight', 'sunset'], useUpdateInterval: true, updateInterval: 86400 * 1000, animationSpeed: 2.5 * 1000, language: "en", showAdzanAlert: true, alertTimer: 15000 } }, { module: 'MMM-RandomQuranAyah', position: 'top_bar', config: { apiVersion: '1.0', showArabic: true, showTranslation: true, surahArabicName:false, translationLang:'de.Aburida', updateInterval: 3600 * 100, } }, { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_right" }, { module: "calendar", header: "Ferien Deutschland", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "bottom_bar" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
